Home » Modeling » Papyrus » How to apply the stereotype" SwSchedulableResource" (How to apply the stereotype" SwSchedulableResource" )
How to apply the stereotype" SwSchedulableResource" [message #1020308] Sun, 17 March 2013 22:11 Go to next message
sabrina ing is currently offline sabrina ingFriend
Member
I have created a package and I want to apply the stereotype "SwSchedulableResource" for
this package.
I used :
Package pkg=(Package) ((Package) (owner)).createNestedPackage("RTOS_Model");
			pkg.applyStereotype(pkg.getApplicableStereotype("MARTE::MARTE_Foundations::GRM::SwSchedulableResource"));
But, It doesn't work.
Can you help me please.
Thanks in advance,
[Updated on: Sun, 17 March 2013 22:12]
Report message to a moderator
Re: How to apply the stereotype" SwSchedulableResource" [message #1020327 is a reply to message #1020308] Sun, 17 March 2013 23:25 Go to previous messageGo to next message
Simon Schwichtenberg is currently offline Simon SchwichtenbergFriend
do you load the marte profile programmatically before?
does getApplicableStereotype return a Stereotype or null?
Re: How to apply the stereotype" SwSchedulableResource" [message #1020563 is a reply to message #1020308] Mon, 18 March 2013 13:27 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Mariem,
What does "doesn't work" mean? Do you get an exception? Do you just
not see the stereotype applied?
Is the MARTE::MARTE_Foundations::GRM profile applied to the RTOS_Model
package or some package that contains it? Note that any of the many
nested profiles in MARTE whose stereotypes you want to use has to be
applied separately. There is no single profile that you can apply that
makes all of the MARTE stereotypes available.
Christian
On 2013-03-17 22:11:44 +0000, Mariem Makni said:
> this package.
> I used :
> Thanks in advance,
Re: How to apply the stereotype" SwSchedulableResource" [message #1020597 is a reply to message #1020563] Mon, 18 March 2013 14:39 Go to previous messageGo to next message
Member
Thanks for your reply.
When I apply the stereotype "SwSchedulableResource" for package or class, I get an
exception.
I tried to change the stereotype by another stereotype like
"MARTE::MARTE_AnalysisModel::GQAM::GaAnalysisContext", the stereotype
"GaAnalysisContext" is applied without any problem.
Is that the path of the profile application
"MARTE::MARTE_Foundations::GRM::SwSchedulableResource" is correct?
Re: How to apply the stereotype" SwSchedulableResource" [message #1020637 is a reply to message #1020597] Mon, 18 March 2013 15:55 Go to previous message
On 2013-03-18 14:39:18 +0000, Mariem Makni said:
> class, I get an
> exception.
That stereotype is in the GQAM profile. It's a different profile from GRM.
I don't know. Is the GRM profile applied to your package? DOes the
SwSchedulableResource stereotype exist in the GRM profile?
Previous Topic:Create Papyrus Project From UML file Using Java
Next Topic:Show/Hide contents question
Current Time: Tue Jan 19 03:34:12 GMT 2021
Powered by FUDForum. Page generated in 0.02081 seconds
