Home » Modeling » EMF » How to control default javadoc creation..(Switching off default Javadoc content..)
Re: How to control default javadoc creation.. [message #1020413 is a reply to message #1020241] |
Mon, 18 March 2013 05:38 |
Ed Merks Messages: 33137 Registered: July 2009 |
Kapil,
Comments below.
On 17/03/2013 6:30 PM, Kapil Gambhir wrote:
> Ed, appreciate a prompt response.
> Yes i tried the approach that u mentioned and this way the custom doc
> content (i.e. value of key "documentation"), mentioned in the ecore is
> generated inside <!-- begin-model-doc --> ..<!-- end-model-doc --> and
> the earlier one is not emitted.
Exactly.
> The challenge i have is that the number of these instances is quite
> high (and thus not efficient to be done manually).
No, though it's only a few lines of code to read and Ecore resource, and
use Resource.getAllContents to visit each EStructuralFeature and use
EcoreUtil.setDocumentation("").
> I guess the intent of this default value is to ensure owners provide
> something meaningful,
Yes.
> but am wondering if its a good idea to provide a ecore directive to
> switch it off, which is also an indication that the owner of the model
> owns what comes out.
I suppose so. Yet more options...
> As a side note, if i want to hide the documentation for certain
> elements or attributes, would the ecore:ignore of the
> xsd:documentation help.
Yes or on the xsd:annotation itself.
Ed Merks
Re: How to control default javadoc creation.. [message #1020568 is a reply to message #1020413] |
Mon, 18 March 2013 13:32 |
Hi, Ed, Kapil,
Is this bit of the Javadoc overrideable in custom templates? If not,
factoring it out into a *.javajetinc could be a lighter-weight solution
than adding an option to the GenModel.
cW
On 2013-03-18 05:38:10 +0000, Ed Merks said:
> Kapil,
> Comments below.
> Exactly.
> and use Resource.getAllContents to visit each EStructuralFeature and
> use EcoreUtil.setDocumentation("").
> Yes.
>> elements or attributes, would the ecore:ignore of the xsd:documentation
>> help.
Re: How to control default javadoc creation.. [message #1020571 is a reply to message #1020568] |
Mon, 18 March 2013 13:39 |
Christian,
There's only //Class/getGenFeature.javadoc.override.javajetinc that
affects the entire Javadoc comment, not just this part.
On 18/03/2013 2:32 PM, Christian W. Damus wrote:
> Hi, Ed, Kapil,
> solution than adding an option to the GenModel.
> cW
>> Kapil,
>> Comments below.
>>> doc content (i.e. value of key "documentation"), mentioned in the
>>> ecore is generated inside <!-- begin-model-doc --> ..<!--
>>> end-model-doc --> and the earlier one is not emitted.
>> Exactly.
>> Yes.
>>> model owns what comes out.
Ed Merks
Current Time: Fri Apr 19 23:38:27 GMT 2024
Powered by FUDForum. Page generated in 0.03872 seconds
