Home » Eclipse Projects » Subversive » NullPointerException
NullPointerException [message #13858] |
Thu, 21 February 2008 22:04 |
I just migrated from the subversion 1.1 (update side from polarion) to
subversion 0.7 (from eclipse.org).
If I try to commit my project I receive:
SVN: '0x0040011a: Call Menu Action' operation finished with error: null
If I press "Send report" I receive:
SVN: 'Open Report Editor' operation finished with error:
org.eclipse.mylyn.internal.bugzilla.core.BugzillaRepositoryC onnector.setupNewBugAttributes(Lorg/eclipse/mylyn/tasks/core /TaskRepository;Lorg/eclipse/mylyn/tasks/core/RepositoryTask Data;)V
For the full report please see below. Any advice?
Best regards, Lars
Version: 0.7.0.v20080218
SVN Client: org.eclipse.team.svn.connector.svnkit15 2.0.0.v20080214 SVNKit
1.2.0 alpha (http://svnkit.com/) rHEAD
JVM Properties:
{java.vendor=Sun Microsystems Inc.,
org.osgi.supports.framework.extension=true, sun.management.compiler=HotSpot
Client Compiler, osgi.framework.beginningstartlevel=1, os.name=Windows XP,
osgi.ws=win32, sun.desktop=windows, java.vm.specification.vendor=Sun
Microsystems Inc., java.runtime.version=1.6.0_03-b05,
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off,
osgi.instance.area=file:/C:/Documents and
Settings/d034797/Desktop/Documents/08_MyDocuments/10_Eclipse /Documentation2/,
http.proxyPort=8080, user.name=d034797, org.osgi.framework.language=en,
user.language=en, org.osgi.framework.processor=x86,
osgi.syspath=c:\Eclipse\plugins, sun.boot.library.path=C:\Program
Files\Java\jre1.6.0_03\bin,
osgi.manifest.cache=C:\Eclipse\configuration\org.eclipse.osg i\manifests,
osgi.compatibility.bootdelegation=true, eof=eof, java.version=1.6.0_03,
org.osgi.framework.os.name=WindowsXP, user.timezone=Europe/Berlin,
sun.arch.data.model=32, http.nonProxyHosts=127.0.0.1|localhost,
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_03\lib\endorsed,
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86, sun.jnu.encoding=Cp1252, file.encoding.pkg=sun.io,
org.osgi.framework.vendor=Eclipse, file.separator=\,
java.specification.name=Java Platform API Specification,
java.class.version=50.0, user.country=US,
org.eclipse.equinox.launcher.splash.location=C:\Eclipse\\plu gins\org.eclipse.platform_3.3.2.R33x_v20071022\splash.bmp,
java.home=C:\Program Files\Java\jre1.6.0_03, osgi.os=win32,
eclipse.commands=-os win32 -ws win32 -arch x86 -showsplash
C:\Eclipse\\plugins\org.eclipse.platform_3.3.2.R33x_v2007102 2\splash.bmp -launcher
C:\Eclipse\eclipse.exe -name Eclipse --launcher.library
C:\Eclipse\plugins\org.eclipse.equinox.launcher.win32.win32. x86_1.0.2.R331_v20071019\eclipse_1021.dll
-startup
C:\Eclipse\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v 20070828.jar -data
C:\Documents and
Settings\d034797\Desktop\Documents\08_MyDocuments\10_Eclipse \Documentation2
-vm C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll ,
java.vm.info=mixed mode,
osgi.splashLocation=C:\Eclipse\\plugins\org.eclipse.platform _3.3.2.R33x_v20071022\splash.bmp,
os.version=5.1, osgi.arch=x86, path.separator=;,
java.vm.version=1.6.0_03-b05, org.osgi.supports.framework.fragment=true,
user.variant=, osgi.framework.shape=jar, http.proxySet=true,
osgi.instance.area.default=file:/C:/Documents and
Settings/d034797/workspace/,
java.awt.printerjob=sun.awt.windows.WPrinterJob,
sun.io.unicode.encoding=UnicodeLittle, org.osgi.framework.version=1.4.0,
awt.toolkit=sun.awt.windows.WToolkit, osgi.install.area=file:/C:/Eclipse/,
osgi.framework=file:/c:/Eclipse/plugins/org.eclipse.osgi_3.3 .1.R33x_v20070828.jar,
user.home=C:\Documents and Settings\d034797,
osgi.bundlestore=C:\Eclipse\configuration\org.eclipse.osgi\b undles,
osgi.splashPath=platform:/base/plugins/org.eclipse.platform, osgi.nl=en_US,
java.specification.vendor=Sun Microsystems Inc.,
java.library.path=C:\Eclipse;.;C:\WINDOWS\Sun\Java\bin;C:\WI NDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_03\bin\client;C:\Program
Files\Java\jre1.6.0_03\bin;C:\Program Files\PC Connectivity
Solution\;C:\Program
Files\ThinkPad\Utilities;C:\PROGRA~1\SECUDE\SECUDE~1;C:\WIND OWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Java\jdk1.6.0_02\bin;C:\Program Files\Common
Files\OpSession\Shared;C:\Program Files\Common Files\OpSession\Viewer
Shared;C:\Program Files\SAP\FrontEnd\SAPgui;C:\Program Files\Common
Files\GTK\2.0\bin;C:\Program Files\QuickTime\QTSystem\,
java.vendor.url=http://java.sun.com/, org.osgi.framework.os.version=5.1,
eclipse.startTime=1203631234906, java.vm.vendor=Sun Microsystems Inc.,
java.runtime.name=Java(TM) SE Runtime Environment,
java.class.path=C:\Eclipse\plugins\org.eclipse.equinox.launc her_1.0.1.R33x_v20070828.jar,
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off,
eclipse.vm=C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll,
java.vm.specification.name=Java Virtual Machine Specification,
java.vm.specification.version=1.0, sun.cpu.endian=little,
sun.os.patch.level=Service Pack 2,
org.apache.commons.logging.simplelog.defaultlog=off,
java.io.tmpdir=C:\DOCUME~1\d034797\LOCALS~1\Temp\,
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi,
http.proxyHost=proxy, eclipse.product=org.eclipse.sdk.ide, os.arch=x86,
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment,
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_03\lib\ext;C:\WINDOWS\Sun\Java\lib\ext,
user.dir=C:\Eclipse, org.osgi.supports.framework.requirebundle=true,
line.separator=
, java.vm.name=Java HotSpot(TM) Client VM,
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog,
eclipse.ee.install.verify=false, file.encoding=Cp1252,
osgi.framework.version=3.3.1.R33x_v20070828, eclipse.buildId=M20070921-1145,
eclipse.vmargs=-XX:PermSize=128M -XX:MaxPermSize=512M -Djava.class.path=C:\Eclipse\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20070828.jar
, java.specification.version=1.6,
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6,
osgi.logfile=C:\Documents and
Settings\d034797\Desktop\Documents\08_MyDocuments\10_Eclipse \Documentation2\.metadata\.log,
osgi.configuration.area=file:/C:/Eclipse/configuration/}
at java.util.Arrays$ArrayList.<init>(Unknown Source)
at java.util.Arrays.asList(Unknown Source)
at
org.eclipse.team.svn.ui.utility.CommitActionUtility.initiali ze(CommitActionUtility.java:57)
at
org.eclipse.team.svn.ui.utility.CommitActionUtility.<init>(CommitActionUtility.java:50)
at
org.eclipse.team.svn.ui.action.local.CommitAction.runImpl(Co mmitAction.java:40)
at
org.eclipse.team.svn.ui.action.AbstractSVNTeamAction$2.runIm pl(AbstractSVNTeamAction.java:61)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:72)
at
org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:37)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:80)
at
org.eclipse.team.svn.ui.action.AbstractSVNTeamAction.run(Abs tractSVNTeamAction.java:58)
at
org.eclipse.team.internal.ui.actions.TeamAction.runWithEvent (TeamAction.java:515)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Re: NullPointerException [message #13864 is a reply to message #13858] |
Thu, 21 February 2008 23:13 |
after reinstalling a fresh copy of Eclipse (and new checkout of the project
the plug-in works fine. I assume there was an issue with my old Polarion
version.
Best regards, Lars
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:fpkshg$gn$1@build.eclipse.org...
> Best regards, Lars
> JVM Properties:
> sun.management.compiler=HotSpot Client Compiler,
> osgi.framework.beginningstartlevel=1, os.name=Windows XP, osgi.ws=win32,
> sun.desktop=windows, java.vm.specification.vendor=Sun Microsystems Inc.,
> -startup
> C:\Documents and
> osgi.nl=en_US, java.specification.vendor=Sun Microsystems Inc.,
> line.separator=
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Thu Apr 25 11:42:12 GMT 2024
Powered by FUDForum. Page generated in 0.03724 seconds
