Home » Modeling » TMF (Xtext) » using the index to check for duplicates
using the index to check for duplicates [message #1018774] Thu, 14 March 2013 12:55 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
looking at Christian's answer in the thread
http://www.eclipse.org/forums/index.php/mv/msg/261440/754503/#msg_754503
I was trying to check for duplicates across multiple files using the code
public class MyDslJavaValidator extends AbstractMyDslJavaValidator {
@Inject
ResourceDescriptionsProvider resourceDescriptionsProvider;
@Inject
IContainer.Manager containerManager;
@Check(CheckType.NORMAL)
public void checkGreetingsDuplicate(Greeting greeting) {
Set<QualifiedName> names = new HashSet<QualifiedName>();
IResourceDescriptions resourceDescriptions =
resourceDescriptionsProvider.getResourceDescriptions(greeting.eResource());
IResourceDescription resourceDescription =
resourceDescriptions.getResourceDescription(greeting.eResource().getURI());
for (IContainer c :
containerManager.getVisibleContainers(resourceDescription,
resourceDescriptions)) {
for (IEObjectDescription od :
c.getExportedObjectsByType(MyDslPackage.Literals.GREETING)) {
if (!names.add(od.getQualifiedName())) {
error("duplicate greeting", MyDslPackage.Literals.GREETING__NAME);
However, at least in a plugin project, the same name (of the same
element) appears in different containers as far as I understand (by
debugging I see StateBasedContainer, EObjectDescriptionImpl,
DescriptionAddingContainer), thus the above strategy raises an error
even for a single element (in this example Greeting), though there are
actually no duplicates.
Thus, in general, one should use a new set in the inner loop (and exit
as soon as there's an error, otherwise, the same error is reported twice):
for (IContainer c :
// each time create a new set
// avoid reporting the same error twice
return;
can anyone confirm this please?
thanks
Lorenzo
HOME: http://www.lorenzobettini.it
Re: using the index to check for duplicates [message #1018932 is a reply to message #1018774] Thu, 14 March 2013 18:05 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Lorenzo,
first you should check for duplicates in the local resource for
efficiency reasons and more helpful user feedback. If the local resource
is valid, a full check could be performed. There you may want to use the
list of visible containers but filter for descriptions from the very
same resource. This should do the trick.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 14.03.13 13:55, schrieb Lorenzo Bettini:
> Hi
> @Inject
> @Inject
> for (IContainer c :
> for (IContainer c :
> return;
> thanks
> Lorenzo
Re: using the index to check for duplicates [message #1019261 is a reply to message #1018932] Fri, 15 March 2013 10:31 Go to previous messageGo to next message
On 03/14/2013 07:05 PM, Sebastian Zarnekow wrote:
> Hi Lorenzo,
Hi Sebastian
actually in this code I don't want to check for duplicates in the very
resource (I have a validator method specific for that, or I'm simply
relying on NamesAreUniqueValidator): in this method I want to check that
there are no duplicates across different files, thus I want the object
descriptions from different resources (that's also the intention of the
answer found at
http://www.eclipse.org/forums/index.php/mv/msg/261440/754503/#msg_754503 ).
Thus, for instance, I want to avoid situations like (this is a
simplified example, the real context is a language with qualified names,
imports, etc.)
first.mydsl contains
Hello foo! // (1)
second.mydsl contains
Hello foo! // (2)
However, as I said in the original post, I seem to understand that in an
Eclipse instance, if you write your DSL programs in a plugin project,
there are several different containers storing qualified names
StateBasedContainer [ 'foo' referring to (1), 'foo' referring to (2), ... ]
DescriptionAddingContainer [ 'foo' referring to (1), 'foo' referring to
(2), ... ]
thus I should NEVER flatten the containers lists, otherwise I end up with
[ 'foo' referring to (1), 'foo' referring to (2), ... , 'foo' referring
right?
in particular this flattening would raise a duplicate error even if
there is no duplicate, e.g., even if there's only one file in my project
with a single Hello foo, the containers would be
StateBasedContainer [ 'foo' ... ]
DescriptionAddingContainer [ 'foo' ... ]
and flattened they would give
[ 'foo' ... , 'foo' ... ]
which would raise a duplicate error, while there's no duplicate.
Thus my original question was: the correct way of checking for duplicate
names in different files, is not the one found at
which I report partially
for (IContainer c :
error("duplicate greeting"...
which implicitly flattens all the lists of containers
but
for (IContainer c :
error("duplicate greeting", ...);
return;
which scans a container's list at time (and exits as soon a duplicate is
found). Is that correct?
I mean, this second solution works, but I wanted to be sure that it is
the right strategy to use the index for looking for duplicates.
By the way, the problems I was telling about are not showing in a junit
scenario, since there's basically only one container. It's only when you
use the DSL editor for a program in an Eclipse plugin project.
thanks
Lorenzo
Re: using the index to check for duplicates [message #1019302 is a reply to message #1019261] Fri, 15 March 2013 12:05 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Lorenzo,
does this work is you really have two containers aka projects?
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: using the index to check for duplicates [message #1019317 is a reply to message #1019302] Fri, 15 March 2013 12:37 Go to previous messageGo to next message
On 03/15/2013 01:05 PM, Christian Dietrich wrote:
> Lorenzo,
> ~Christian
Christian, I'm not sure what you mean but what happens is that, if I use
my solution
- I correctly get errors if I have elements with the same name
(qualified name) in two different files of the same project
- I don't get errors if these two files are in different projects
- most of all, I don't get false errors (because the same name of the
same element is in several visible containers)
by error I mean "duplicate greeting" error issued by the validator's
check method
or did you mean something else?
Concerning your original code, does it work for you? Because what happens is
- even with a single file I get a false error with a single element
(since it appears in several visible containers)
I can try to put on github an example (as soon as I have time :)
thanks in advance
Lorenzo
Re: using the index to check for duplicates [message #1019319 is a reply to message #1019317] Fri, 15 March 2013 12:44 Go to previous messageGo to next message
In Our Project where have following setup
(a) Project A
- Greeting "Test"
(b) Project B referenceing Project A
- Greeting "Test"
=> if we check Project B we want to get a duplicate error (since the Greeting "Test" from (a) is visible in (b)
this is why we build the set outside the visbile container loop.
Re: using the index to check for duplicates [message #1019321 is a reply to message #1019319] Fri, 15 March 2013 12:46 Go to previous messageGo to next message
P.S: we have an additional if that compares the uris of the found greetings in the code,
so maybe this makes the difference.
Re: using the index to check for duplicates [message #1019354 is a reply to message #1019319] Fri, 15 March 2013 14:18 Go to previous messageGo to next message
> (a) Project A - Greeting "Test"
> - Greeting "Test"
are they Java projects or Plug-in projects?
cheers
Lorenzo
Re: using the index to check for duplicates [message #1019416 is a reply to message #1019354] Fri, 15 March 2013 16:22 Go to previous messageGo to next message
neither nor. simple "general -> project" projects
Re: using the index to check for duplicates [message #1019783 is a reply to message #1019416] Sat, 16 March 2013 16:51 Go to previous message
OK, because the problem I raised happens when you use a plug-in project :)
Previous Topic:Xtext Integration with GMF
Next Topic:Lightweight standalone AST parser
Current Time: Sun Feb 28 04:51:57 GMT 2021
Powered by FUDForum. Page generated in 0.01820 seconds
