Home » Archived » BIRT » BIRT performance issue regarding the parameter window(BIRT performance issue regarding the parameter window)
BIRT performance issue regarding the parameter window [message #1018727] Thu, 14 March 2013 11:12 Go to next message
steven chen is currently offline steven chenFriend
HI,Experts
recently one of our customers met a performance issue regarding birt report. when they tried to start a report, it could cost quite a long time for parameter window to appear. i tried to use http watch to locate what's consuming the most time but not doing it yet.
So hope any one could share some tips or ideas for this and much thanks in advance.
Steven
Re: BIRT performance issue regarding the parameter window [message #1018843 is a reply to message #1018727] Thu, 14 March 2013 15:02 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Are any of the parameters dynamic? Are they tied to a query that is running long?
Re: BIRT performance issue regarding the parameter window [message #1018913 is a reply to message #1018843] Thu, 14 March 2013 17:24 Go to previous messageGo to next message
Hi, Jason
Thanks for your reply.
here is the situation:
1) most of the reports should not be tied to a query running long.
2) the parameter should be dynamic with a list of parameters which could be chose by end users.
Steven
[Updated on: Thu, 14 March 2013 17:29]
Report message to a moderator
Re: BIRT performance issue regarding the parameter window [message #1018927 is a reply to message #1018913] Thu, 14 March 2013 17:51 Go to previous messageGo to next message
just confirmed again, should *not* be the dynamic parameters.
Steven
Re: BIRT performance issue regarding the parameter window [message #1018966 is a reply to message #1018927] Thu, 14 March 2013 19:57 Go to previous messageGo to next message
What version of BIRT are they using and how are they displaying the reports (ie are they using the Viewer)?
Re: BIRT performance issue regarding the parameter window [message #1019095 is a reply to message #1018966] Fri, 15 March 2013 02:51 Go to previous messageGo to next message
Hi, Jason
Hi, Jason
the birt viewer is 2.5.1.
I am not familar with birt but according to the log, it should have been using viewer.
2013-03-14 00:17:18,954 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) org.eclipse.birt.report.exception.ViewerException: ±¨¸æÎļþ:/wms/sce/jboss-5.1.0.GA/server/scprd-reports2/tmp/au94t-ndhlru-he5jht30-1-he5jj6fz-9s/scereports.war/report/billing/ZTE_ProdplanNoStatusQuery_V2.rptdesign ²»´æÔÚ»òÕß°üº¬´íÎó¡£
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.ViewerAttributeBean.getDesignHandle(ViewerAttributeBean.java:647)
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.ViewerAttributeBean.__init(ViewerAttributeBean.java:224)
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.BaseAttributeBean.init(BaseAttributeBean.java:233)
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:118)
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.BirtContext.__init(BirtContext.java:44)
2013-03-14 00:17:18,955 ERROR [STDERR] (http-wms1%2F10.30.9.173-8280-27) at org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69)
"server.log.2013-03-14" 765L, 129733C
Re: BIRT performance issue regarding the parameter window [message #1019227 is a reply to message #1018913] Fri, 15 March 2013 09:17 Go to previous messageGo to next message
Hi, Jason
FYI, this issue was caused by the IE and network settings. It has been fixed.
Steven
Re: BIRT performance issue regarding the parameter window [message #1021134 is a reply to message #1019227] Tue, 19 March 2013 15:10 Go to previous message
Steven
Thanks for the update. Which network setting?
Previous Topic:Help - Passing multiple parameters and values through URL without exceeds.
Next Topic:Bug in Crosstab Aggregation
Current Time: Mon Sep 25 08:40:34 GMT 2023
Powered by FUDForum. Page generated in 0.02249 seconds
