Home » Newcomers » Newcomers » Juno/Indigo has less perspectives.(Unable to stop running server.)
Juno/Indigo has less perspectives. [message #1018319] Wed, 13 March 2013 15:58 Go to next message
paul b is currently offline paul bFriend
Hello I set up eclipse on Windows7 and installed the JEE platform (eclipse). On my Freebsd machine this would be Indigo but windows called it Juno. In Indigo I can get a server perspective and start and run my Red5-plugin. However there's no perspective for that with Juno.
What am I missing? Please
Re: Juno/Indigo has less perspectives. [message #1018349 is a reply to message #1018319] Wed, 13 March 2013 16:42 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
There's not quite enough information.
Indigo and Juno are separate releases of Eclipse. If you didn't know
that, it's because when you installed on FreeBSD, you used some software
control center or something. (You should never install Eclipse from
anywhere but eclipse.org, which is doubtless what you did for Windows.)
Perhaps you didn't download Eclipse IDE for Java EE Developers in the
case of your Windows installation. You can either go do that over again
or you can use Help -> Install New Software to add the Eclipse web tools.
Re: Juno/Indigo has less perspectives. [message #1018358 is a reply to message #1018349] Wed, 13 March 2013 17:06 Go to previous messageGo to next message
I installed to windows on a Virtual Machine. My eclipse distibution on windows eclipse-jee-juno-SR2-win32.zip from http://www.eclipse.org.
Thats the one I'm having problems with.
I Installed windows to install this flashdevelop and I also run the examples in Eclipse since they don't work with Freebsd without updating Eclipse. Something that can't be done with the port.
________________________________________________________
However FYI Eclipse isn't install on Freebsd today. Without that port It almost imposible for me to run it. I have tried many times in the past.
I'm going to try today and run it. I had a problem with the red5-plugin that I solved. By changing my SHELL
[Updated on: Wed, 13 March 2013 17:28]
Report message to a moderator
Re: Juno/Indigo has less perspectives. [message #1018371 is a reply to message #1018358] Wed, 13 March 2013 17:51 Go to previous messageGo to next message
> http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/juno/SR2/eclipse-jee-juno-SR2-win32.zip.
> I Installed windows to install this flashdevelop.org and I thought I
> would run the examples in Eclipse also since they don't work in Freebsd
Okay, that's good. Is this an Eclipse problem? If Red5/flashdevelop.org
has a forum, you might find more joy in asking them. Or, someone with
more understanding than I may come along here.
Best of luck.
Re: Juno/Indigo has less perspectives. [message #1018381 is a reply to message #1018371] Wed, 13 March 2013 18:26 Go to previous messageGo to next message
Sorry I mention flashdevelop or replied back about installing other eclipse's on what.
So about juno:
how do you get a panel that has a wizzard to add and stop and start the exteral servers like tomcat and the red5 plugin.
PS: I mentioned Flashdevelop but does eclipse have something that can open swf by the way.?
[Updated on: Wed, 13 March 2013 18:32]
Re: Juno/Indigo has less perspectives. [message #1018394 is a reply to message #1018381] Wed, 13 March 2013 18:54 Go to previous message
> eclipse's that you suggested on what.
> So about juno:
> PS: I mentioned Flashdevelop but does eclipse have something like can
Window -> Show View -> Servers
Don't know "swf" myself.
Previous Topic:Eclipse
Next Topic:Cursor position missing in Eclipse editor
Current Time: Tue Apr 16 22:58:57 GMT 2024
Powered by FUDForum. Page generated in 1.73116 seconds
