Problem with using windows resource files [message #1017781] |
Tue, 12 March 2013 14:29 |
Ben G. Messages: 1 Registered: March 2013 |
Hi all,
I just started using Eclipse and CDT (together with MinGW) and came across a small problem when using windows resource files (*.rc). I started building a small GUI with the WINAPI consisting of a menu bar with some items. Pressing the left mouse-button should display an extra window dialog using the CreateDialog() method.
I wrote the *.rc files of both the menu and the dialog myself with a texteditor. Using "C/C++ Build->Settings->Build Steps->Pre-build steps" I'm using windres.exe to create the corresponding *.o files. Also, these *.o files are linked using "C/C++ Build->Settings->Tool Setting->MinGW C++ Linker->Miscellaneous->Other objects".
So, here comes the problem:
If the first entry of my 'Other objects'-List is my menu.o the menu bar is displayed. When I click the left mouse-button, no extra window dialog comes up because the CreateDialog()-method returns NULL.
If I move up my dialog.o and so the first entry of my 'Other objects'-List is my dialog.o, then no menu bar is displayed but when I click the left mouse-button now, the extra window dialog comes up.
Thus, I cannot have both the menu and the extra dialog window. The same happens if I want to open the extra dialog window by pressing an item in the menu bar.
Does anyone know what I'm doing wrong?
Thanks in advance!
FUDForum. Page generated in 0.02554 seconds
