Home » Modeling » OCL » import platform-resource to completeoclfile
import platform-resource to completeoclfile [message #1017213] |
Mon, 11 March 2013 08:05 |
Ba sti Messages: 18 Registered: February 2013 |
I´m trying to create a CompleteOCL-file to validate a Profile that is applied on a uml-model. The profile is saved in a external uml-file so i have to import this file to the completeOCL-file, but eclipse says that this is an unresolved import:
"Unresolved import 'platform:/resource/Profile/Profile.uml' : Failed to load 'pivot:/platform/resource/Profile/Profile.uml' : Unnamed package"
This is my ocl-file:
import uml: 'http://www.eclipse.org/uml2/3.0.0/UML#/'
import signal: 'platform:/resource/Profile/Profile.uml'
context uml::Class
inv Defined:
let stereo: Stereotype= self.getAppliedStereotype('Profile::Protokoll') in not stereo.oclIsUndefined()implies (self.getValue(stereo,'ID').oclAsType(Integer) > 0
I´m running this file with a CompleteOCLEObjectValidator in standalone(but running it inside eclipse makes no difference) and when i tried to run this with the file above i get the error:
"0 [main] ERROR idation.CompleteOCLEObjectValidator - Failed to load 'file:/D:/PapyrusWorkspacee/standalone_validierer/src/profile.ocl
2: Unresolved import 'platform:/resource/Profile/Profile.uml' : The path '/Profile/Profile.uml' is unmapped"
Thats my validator:
CompleteOCLStandaloneSetup.doSetup();
OCLstdlib.install();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getPackageRegistry().put("pathmap://Papyrus.profile.uml",UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(resourceSet.getResourceFactoryRegistry().DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
URI uri = URI.createFileURI(args[0]);
URI ocluri = URI.createFileURI(args[1]);
EPackage.Registry.INSTANCE.put(args[0],UMLPackage.eINSTANCE);
Resource resource = resourceSet.createResource(uri);
try {
resource.load(null);
System.out.println("Model: load complete");
} catch (IOException e) {
e.printStackTrace();
Model m = (Model) EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.MODEL);
if(m==null){
System.err.println("Model: load failed!");
System.exit(1);
CompleteOCLEObjectValidator val = new TestValidator(UMLPackage.eINSTANCE,ocluri);
EValidator.Registry.INSTANCE.put(UMLPackage.eINSTANCE,val);
EValidator.Registry.INSTANCE.put(SysmlPackage.eINSTANCE,val);
Diagnostic diag = Diagnostician.INSTANCE.validate(m);
System.out.println(diag.getMessage());
for(Diagnostic object : diag.getChildren()){
System.err.println(object.getMessage());
I´m using the KeplerM5-release..
What´s the problem with this import?
Is it necessary to do some special registrations in the java-file/the project containing it?
Basti
Re: import platform-resource to completeoclfile [message #1017594 is a reply to message #1017213] |
Tue, 12 March 2013 06:56 |
Ed Willink Messages: 7655 Registered: July 2009 |
Getting UML registrations correct is extremely difficult and so I
contributed what became UMLResourcesUtil.init(). If you can do better
you are welcome to do so and then contribute it back to Eclipse.
Imperfections in UMLResourcesUtil.init() are addressed by a further
contribution exploiting a recent EMF enhancement that you may find in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401682.
Your code contains pathmap://Papyrus.profile.uml which is odd and has no
obvious resolution.
appears to suggest that wherever your profile is encountered, the UML
metamodel should be consulted for its resolution.
Ed Willink
On 11/03/2013 08:05, Ba sti wrote:
> Hello,
> context uml::Class
> inv Defined:
> (self.getValue(stereo,'ID').oclAsType(Integer) > 0 I´m running this
> Thats my validator:
> try {
> Model m = (Model)
> if(m==null){
> System.exit(1);
> What´s the problem with this import? Is it necessary to do some
> Regards,
> Basti
Current Time: Fri Mar 29 10:51:23 GMT 2024
Powered by FUDForum. Page generated in 0.08552 seconds
