Re: [Theming][Text] Internet Explorer ignores css tags on disabled Text Widgets [message #1017078 is a reply to message #1016927] |
Fri, 08 March 2013 21:05 |
Markus rüger Messages: 369 Registered: July 2009 |
If I remember correctly, this is not an issue of RAP. It is an IE isse thst
dors not allow the change of the background color. Maybe IE10 csn do it,
but IE 7-9 does not. A common workaround is to use readonly instead of
disabled.
Fabian Henniges <forums-noreply@xxxxxxxx> wrote:
> RWT renders Text widgets as HTML input elements with style.
> Disabled Text widgets are rendered as input elements with disabled=true.
> While theming works fine on these elements in mozilla and webkit browsers, IE ignores it.
> You might reproduce it starting up the RAP demo and changing the rendered
> HTML with some web dev tool.
> I do not have an idea how to fix or workaround. You?
> [Binärdaten ausgeblendet...]
[Updated on: Mon, 11 March 2013 18:24] by Moderator Report message to a moderator
FUDForum. Page generated in 0.03229 seconds
