Re: Unable to connect to iseries [message #1016827 is a reply to message #1016823] |
Thu, 07 March 2013 20:13 |
Julie Anderson Messages: 3 Registered: March 2013 |
My eclipse.ini file is:
-vm
C:\Program Files (x86)\IBM\SDP70\jdk\jre\bin\javaw.exe
-vmargs
-Xquickstart
-Xms40m
-Xmx768m
-Xgcpolicy:gencon
-Xscmx96m
-Xshareclasses:singleJVM,keep
-Xnolinenumbers
-XX:MaxPermSize=512M
my config.ini file is:
#Thu Mar 07 14:14:22 EST 2013
com.ibm.SSL.ConfigURL=file\:C\:\\Program Files (x86)\\IBM\\SDP70/runtimes/base_v61_stub/properties/ssl.client.props
osgi.bundles=reference\:file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.update.configurator_3.2.1.v20092006.jar@3\:start,reference\:file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar@start,reference\:file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar@2\:start
cic.appDataLocation=C\:\\ProgramData\\IBM\\Installation Manager
osgi.framework.extensions=com.ibm.cds
osgi.framework=file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.osgi_3.2.2.R32x_v20061101.jar
eclipse.product=com.ibm.etools.iseries.wdsc.welcome.ide
was.runtime=C\:\\Program Files (x86)\\IBM\\SDP70/runtimes
security.overrideProperties=true
osgi.launcherIni=eclipse
osgi.instance.area.default=@user.home/IBM/rationalsdp7.0/workspace
com.ibm.CORBA.ConfigURL=file\:C\:\\Program Files (x86)\\IBM\\SDP70/runtimes/base_v61_stub/properties/sas.client.props
osgi.bundlefile.limit=100
osgi.splashPath=file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/com.ibm.etools.iseries.wdsc.welcome,file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/com.ibm.etools.iseries.wdsc.welcome.nl1,file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/com.ibm.etools.iseries.wdsc.welcome.nl2
osgi.ws=win32
org.eclipse.uml2.common.util.CacheAdapter.INSTANCE=com.ibm.xtools.uml.internal.cacheadapter.UMLCacheAdapter
osgi.bundles.extraData=file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.update.configurator_3.2.1.v20092006.jar,org.eclipse.update.configurator,3.2.1.v20092006,file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar,org.eclipse.core.runtime,3.2.0.v20060603,file\:/C\:/Program Files (x86)/IBM/SDP70Shared/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar,org.eclipse.equinox.common,3.2.0.v20060603
java.security.properties=file\:C\:\\Program Files (x86)\\IBM\\SDP70/runtimes/base_v61_stub/properties/java.security
org.eclipse.emf.ecore.EPackage.Registry.INSTANCE=org.eclipse.emf.ecore.impl.EPackageRegistryImpl
osgi.launcherPath=C\:\\Program Files (x86)\\IBM\\SDP70
com.ibm.xtools.emf.collections.HashedCollectionFactory=true
Can anyone tell me why I cannot sign on??
FUDForum. Page generated in 0.08040 seconds
