Home » Modeling » EMF » Undo/Redo two Commands at once
Undo/Redo two Commands at once [message #1016463] Wed, 06 March 2013 14:55 Go to next message
Ralph P is currently offline Ralph PFriend
Member
I created an action that creates two Command-chains that must be executed one after another.
The problem is, that "Undo" only 'undoes' the second Command-chain, which leads to an inconsistent state.
Is there a possibility to execute both Command-chains in a way that they will be undone with one Undo-Command (same for Redo)?
I'm thinking of adding an CommandStackListener to manually execute both Command-chains on Undo/Redo but this doesn't seem to be an elegant way (or is it?).
Thanks in advance!
Ralph
Re: Undo/Redo two Commands at once [message #1016475 is a reply to message #1016463] Wed, 06 March 2013 15:20 Go to previous messageGo to next message
Christophe Bouhier is currently offline Christophe BouhierFriend
On 06-03-13 15:55, Ralph P wrote:
What's a command-chain? Do you mean you have two sets of
CompoundCommands? or you have 'regular' commands executing in sequence?
Isn't CompoundCommand what you are looking for?
> (or is it?).
> Thanks in advance!
> Best regards,
> Ralph
Re: Undo/Redo two Commands at once [message #1016485 is a reply to message #1016475] Wed, 06 March 2013 16:00 Go to previous messageGo to next message
Member
Hi Christophe,
thanks you for your help!
It's a bunch of Add- and SetCommands chained together with Command#chain(Command) (so actually I have two AbstractCommands to execute).
Actually, StrictCompoundCommand at first sounds just like what I was looking for. But the following paragraph from the JavaDoc is probably the reason why it's not working for me:
 * It is important for all but the last command to have no visible side-effect!
 * Multiple commands with visible side-effects must be composed into a single command using just a {@link CompoundCommand}
 * and that composite could be the last command of a strict composite.
I have only commands with visible side effects.
I will have a closer look at that tomorrow!
Ralph
Re: Undo/Redo two Commands at once [message #1016517 is a reply to message #1016463] Wed, 06 March 2013 18:12 Go to previous messageGo to next message
Ralph,
Is sounds like you just need to compose the two of them into a single
CompoundCommand... That's all the chains do under the covers too...
On 06/03/2013 3:55 PM, Ralph P wrote:
> Thanks in advance!
> Best regards,
> Ralph
Ed Merks
Re: Undo/Redo two Commands at once [message #1016632 is a reply to message #1016517] Thu, 07 March 2013 08:26 Go to previous messageGo to next message
Member
Thanks for the help! I found why it was not working even with a compound command.
The second Command(-chain) was invalid, since it expected the result of the first Command on creation (which was not yet executed).
In other words I did:
- Create Command 1
- Create Command 2 (<- That's the problem. Command 2 needs Command 1 to be executed before creation/initialization.)
- Execute both commands using a CompoundCommand
I will try to create my own AbstractOverrideableCommand and add it to a CompoundCommand, so it will be using the "new" EObjects after the first Command was executed.
EDIT: Creating a new CompundCommand is probably a better approach.
I know my explanations are kind of blurry, but it is fairly complicated what I'm trying to do(importing EObjects from one Resouruce into another, including lots of EReferences and a merge mechanism).
You already helped me a lot, I have no questions left right now. I'll post a status update as soon as I made some progress.
[Updated on: Thu, 07 March 2013 08:45]
Report message to a moderator
Re: Undo/Redo two Commands at once [message #1016643 is a reply to message #1016632] Thu, 07 March 2013 08:56 Go to previous messageGo to next message
Ralph,
You might want to look at
org.eclipse.emf.common.command.CompoundCommand.appendAndExecute(Command).
> compound command.
> - Create Command 1
> mechanism).
Ed Merks
Re: Undo/Redo two Commands at once [message #1016650 is a reply to message #1016643] Thu, 07 March 2013 09:18 Go to previous message
Member
Hi Ed,
I got it! Thanks both of you!
I did something very similar to the DeleteCommand:
public class ImportCommand extends CompoundCommand {
	protected boolean prepare() {
		Command ic = createImportCommand();
		append(ic);
		return ic.canExecute();
	public void execute() {
		super.execute();
		appendAndExecute(createMaintainCommand());
Ralph
Previous Topic:Non-EMF object XMI serialization
Next Topic:[CDO] Need to refresh the Server after modify security model?
Current Time: Tue Apr 16 10:44:40 GMT 2024
Powered by FUDForum. Page generated in 0.77875 seconds
