Home » Archived » BIRT » Dataset Initialisation
Dataset Initialisation [message #1016323] Wed, 06 March 2013 03:51 Go to next message
David Good is currently offline David GoodFriend
Member
As far as I can tell, stand alone data sets (i.e. not joined etc) are not 'processed' unless one of their fields is part of the report.
I have a report which requires me to process some information in an 'unused' dataset, and pass information to the report.
I have it working as expected but need to place one field from the unused dataset onto the report, to initialize it and make it fetch. I then run code in its onFetch and afterClose.
Qn: Can I force a dataset to fetch, even if it does not have any fields within a report?
David
Re: Dataset Initialisation [message #1016328 is a reply to message #1016323] Wed, 06 March 2013 04:52 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
You might look into using the Data Engine API. Here's a link to a devShare post, from BIRT Exchange:
BIRT Exchange DevShare - Data Engine API to Check Data Set Values
Michael
Developer Evangelist, Silanis
Previous Topic:issue with BIRT REPORT AND REMEDY 7.6
Next Topic:BIRT for Eclipse 4.x
Current Time: Fri Sep 29 11:39:15 GMT 2023
Powered by FUDForum. Page generated in 0.01866 seconds
