Re: Highlighting over item bounds [message #13829 is a reply to message #13789] |
Fri, 13 October 2006 16:52 |
Jeremy Dowdall Messages: 181 Registered: July 2009 |
It's subtle, so I want to make sure you're aware that the
createChildContents method passes in an SComposite for the parameter
"contents", and not a regular Composite.
There have also been changes to the SComposite class, and its creation
in the CContainerCell, so please update them from cvs (there is also the
addition of javadocs in SComposite :))
If the update does not fix this, I probably misunderstand the problem,
in which case please post a small screenshot to show the problem.
cheers
Cal wrote:
> Hi
> This is a nebula/newbie question:
> On selection, I'd like the titleArea and childArea to be highlighted as
> one. I have the bounds highlighted but a little ~halo just around the
> perimeter of the childArea control remains white. I added a border to
> the child contents composite to check it out, area in question is within
> the border. How do I get that painted? Thanks.
> (single control in child composite, fillLayout)
Re: Highlighting over item bounds [message #566625 is a reply to message #13789] |
cheers
Cal wrote:
> Hi
FUDForum. Page generated in 0.03037 seconds
