Re: TableViewer / LabelProvider Images with different width [message #1016614 is a reply to message #1016165] |
Thu, 07 March 2013 07:15 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Jens,
RAP inherited this behavior from SWT Tree/Table. The only workaround I'm
aware of is to enable markup in Table/Tree and set your image together
with the text (markup).
HTH,
Ivan
On 3/7/2013 4:20 AM, Jens Mallien wrote:
> is it possible to have Images with different width in one TableViewer?
> It seems, that TableViewer saves the size of the first image and set this to the width of all images.
> Cols: If another column has a wider Image, it will be cut off at the width of the first image from the first column with an image.
> Rows: If another row has no Image or an Image with another size, it will be cutted off or filled.
> Is there a SWT.Syle or a switch to prevent that check, calculation and resizing of all images to just have images with their original size, regardless of the first found image?
> Regards,
> Jens
Ivan Furnadjiev
Twitter: @EclipseRAP
FUDForum. Page generated in 0.02671 seconds
