Re: Segmentation Fault Issue [message #1015966 is a reply to message #1015653] |
Mon, 04 March 2013 12:43 |
Ajar Behari Messages: 2 Registered: March 2013 |
Thanks Ian , this change solved the segmentation fault issue at the point of Ethernet connection removed. I was able to test subscribe function also and receive messages.
However the re-connection of client to broker in case of Ethernet connection resuming was still an issue :
Case A : The Ethernet cable was removed during a active MQTT session. RSMB detected client connection lost correctly after 20 seconds MQTT timeout. However there was no callback to connlost function on client end. Is there an implementation to detect MQTT ping failure on client end ?
Hope you can give some pointers on above test case. Thanks in advance.
[Updated on: Tue, 05 March 2013 05:51] Report message to a moderator
FUDForum. Page generated in 0.03399 seconds
