Home » Eclipse Projects » Rich Client Platform (RCP) » Reset perspective though command for perspective created by application model not showing any part i(Reset perspective though command for perspective created by application model not showing any part in RCP.)
Reset perspective though command for perspective created by application model not showing any part i [message #1015545] Fri, 01 March 2013 08:36 Go to next message
Sumit Singh is currently offline Sumit SinghFriend
Create RCP in eclipse juno .
Create a perspective using Application.e4xmi, add part stack and part.
And menu resetPerspective using org.eclipse.ui.window.resetPerspective command.
application runs perfect, but if you reset perspective then every think gone.
In JavaScript perspective in same RCP its work fine.
Application before reset.
index.php/fa/13624/0/
Application after Perspective
index.php/fa/13625/0/
Apllication.e4.xmi for above perspective
index.php/fa/13626/0/
  • Attachment: Untitled.png
    (Size: 69.69KB, Downloaded 1847 times)
    (Size: 36.90KB, Downloaded 1991 times)
    (Size: 62.27KB, Downloaded 1782 times)
Re: Reset perspective though command for perspective created by application model not showing any pa [message #1065029 is a reply to message #1015545] Sun, 23 June 2013 16:37 Go to previous message
Tuan Anh Nguyen is currently offline Tuan Anh NguyenFriend
Hi Sumit Singh,
I am learning about eclipse 4 platform too, i got problem with the help menu. Would you please show me how to make the menu like you did ( help , show view, perspective).
Best Regards,
Previous Topic:Pulldown menu: display label of a command
Next Topic:How to Debug RCP application
Current Time: Wed Jan 19 23:29:27 GMT 2022
Powered by FUDForum. Page generated in 0.02641 seconds
