Graphical comparison specification note [message #1015366] |
Thu, 28 February 2013 11:17 |
going through the specification, a little thing came to my mind and I think that i don't see this use case mentioned.
In case of a quite constrained layout that doesn't allow superposition, if two different nodes are added at the same place, shouldn't we have a conflict?
More generally, I think that performing a check on position with the layout would be great, after merge, the diagram should be "layout-valid".
Unfortunately, technically, I'm not sure that it will easy to do :s
Did you already mention about this use case and I missed it? If yes, can you point me to the correct place please.
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
[Updated on: Thu, 28 February 2013 12:05] Report message to a moderator
FUDForum. Page generated in 0.02965 seconds
