Home » Eclipse Projects » GEF » How to make a connector touch the shape
How to make a connector touch the shape [message #147857] Tue, 17 August 2004 13:24 Go to next message
Originally posted by: none.bphnx.com
It should be possible to make a connector touch the shape instead of the
rectangle that surrounds the shape when it is selected, but I cannot
figure out how to do this. For example, when you connect a connector to a
Triangle, the connector does not make contact with the Triangle itself.
Any hints on this?
many thanks,
B
Re: How to make a connector touch the shape [message #147872 is a reply to message #147857] Tue, 17 August 2004 13:55 Go to previous messageGo to next message
Use a different ConnectionAnchor for that shape.
"bandrews" <none@bphnx.com> wrote in message
news:cft0uc$nus$1@eclipse.org...
> Any hints on this?
> many thanks,
> B
Re: How to make a connector touch the shape [message #147942 is a reply to message #147872] Tue, 17 August 2004 18:15 Go to previous messageGo to next message
Ok, so I believe I need to extend the AbstractConnectionAnchor and
override the Point getLocation(Point reference) method. Correct?
thanks,
B
> > Any hints on this?
> > many thanks,
> > B
Re: How to make a connector touch the shape [message #148012 is a reply to message #147872] Wed, 18 August 2004 19:11 Go to previous messageGo to next message
Hi Randy,
I created my own class that extends AbstractConnectionAnchor. I
overrode the getLocation() method, but no matter what my implementation
is, the connector always attaches to the rectangle that surrounds the
shape ( in this case the shape is a diamond ). It seems to have no effect.
I even tried hardcoding a return new Point(100,100);, but it still
attaches to the rectangle around the diamond. I know I am missing
something else. Any help is greatly appreciated.
thanks,
B
> > Any hints on this?
> > many thanks,
> > B
Re: How to make a connector touch the shape [message #148016 is a reply to message #148012] Wed, 18 August 2004 21:23 Go to previous messageGo to next message
Are you sure you didn't override getReferencePoint instead?
Are you setting the anchor on the connection? Is anyone else overwriting
your anchor after you set it?
Put a breakpoint in PolylineConnection.route(), and see what your anchors
are at the time of routing.
news:cg09lv$21p$1@eclipse.org...
> Hi Randy,
> thanks,
> B
the
to a
itself.
> > > Any hints on this?
> > > many thanks,
> > > B
Re: How to make a connector touch the shape [message #148225 is a reply to message #148016] Thu, 19 August 2004 21:05 Go to previous message
Ahhh! The problem was I was overwriting the anchors on the connection
myself. Silly me. Thanks for the hints!
> > Hi Randy,
> > thanks,
> > B
> the
> to a
> itself.
> > > > Any hints on this?
> > > > many thanks,
> > > > B
Previous Topic:Resizing edit part without move
Next Topic:Is it possible to create a semi-transparent figure?
Current Time: Fri Feb 14 19:38:11 GMT 2025
Powered by FUDForum. Page generated in 0.04839 seconds
