Migration to 3.0 - thinBackup problem [message #1014717] |
Tue, 26 February 2013 10:40 |
k z Messages: 71 Registered: October 2012 |
Member |
Problem with thinBackup plugin (1.6.2) after migration to from Hudson 2.2.0 to Hudson 3.0.0
Feb 26, 2013 10:13:21 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - thinBackup
INFO: Failed to load plugin - thinBackup because of error Failed to load plugin instance for: thinBackup
Feb 26, 2013 10:13:21 AM hudson.model.Hudson$5 onTaskFailed
SEVERE: Failed Loading plugin thinBackup
hudson.util.IOException2: Failed to load plugin instance for: thinBackup
at org.hudsonci.inject.internal.plugin.SmoothiePluginStrategy.load(SmoothiePluginStrategy.java:185)
at org.hudsonci.inject.internal.plugin.DelegatingPluginStrategy.load(DelegatingPluginStrategy.java:66)
at hudson.PluginManager$2$1$1.run(PluginManager.java:297)
at org.jvnet.hudson.reactor.TaskGraphBuilder$TaskImpl.run(TaskGraphBuilder.java:146)
at org.jvnet.hudson.reactor.Reactor.runTask(Reactor.java:259)
at hudson.model.Hudson$4.runTask(Hudson.java:647)
at org.jvnet.hudson.reactor.Reactor$2.run(Reactor.java:187)
at org.jvnet.hudson.reactor.Reactor$Node.run(Reactor.java:94)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:679)
Caused by: java.lang.NoClassDefFoundError: antlr/ANTLRException
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getDeclaredConstructors(Class.java:1853)
at com.google.inject.spi.InjectionPoint.forConstructorOf(InjectionPoint.java:243)
at com.google.inject.internal.ConstructorBindingImpl.create(ConstructorBindingImpl.java:96)
at com.google.inject.internal.InjectorImpl.createUninitializedBinding(InjectorImpl.java:629)
at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:845)
at com.google.inject.internal.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:772)
at com.google.inject.internal.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:256)
at com.google.inject.internal.InjectorImpl.getBindingOrThrow(InjectorImpl.java:205)
at com.google.inject.internal.InjectorImpl.getInternalFactory(InjectorImpl.java:853)
at com.google.inject.internal.InjectorImpl.getProviderOrThrow(InjectorImpl.java:967)
at com.google.inject.internal.InjectorImpl.getProvider(InjectorImpl.java:1000)
at com.google.inject.internal.InjectorImpl.getProvider(InjectorImpl.java:961)
at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1013)
at org.hudsonci.inject.internal.plugin.SmoothiePluginStrategy.load(SmoothiePluginStrategy.java:181)
... 10 more
Caused by: java.lang.ClassNotFoundException: antlr.ANTLRException
at org.aspectj.weaver.bcel.ExtensibleURLClassLoader.findClass(ExtensibleURLClassLoader.java:54)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 26 more
SEVERE: Failed Initializing plugin thinBackup
at hudson.PluginManager$2$1$2.run(PluginManager.java:315)
[Updated on: Tue, 26 February 2013 14:06] Report message to a moderator
FUDForum. Page generated in 0.03185 seconds
