Home » Archived » Buckminster » Kepler IDE: Error Message Cannot determine filter for requirement to this element
Kepler IDE: Error Message Cannot determine filter for requirement to this element [message #1014516] |
Tue, 26 February 2013 00:44  |
Lothar Werzinger Messages: 153 Registered: July 2009 Location: Bay Area |
I am getting this peculiar error message with buckminster in the Kepler Milestone IDE:
[start xxx.product.feature:eclipse.feature$5.0.0.qualifier#site.p2]
publishing result
E Included element xxx.product.feature.feature.group 5.0.0.D-lothar-20130226-0040 is missing. Cannot determine filter for requirement to this element.
if I look into the p2 site created by buckminster to create the product I can see
ls /tmp/buckminster/build/xxx.product.feature_5.0.0-eclipse.feature/site.p2/features/xxx.product.feature*
/tmp/buckminster/build/xxx.product.feature_5.0.0-eclipse.feature/site.p2/features/xxx.product.feature_5.0.0.D-lothar-20130226-0040.jar
Searching the web for Cannot determine filter for requirement to this element. together with Buckminster did not yield a single result.
Edit (2013-02-26):
Interestingly the problem only occurs in the IDE (Kepler Milestone) and not if I try to build from Jenkins. As I use the builds in the IDE to verify that the product actually works before I check things in this is a big problem for me right now.
Edit (2-13-03-01):
I double verified that the exact same sources fail reproducibly to build in the Kepler IDE at the site.p2 step but build fine in the Juno IDE. Here's the console log from Juno:
[start xxx.feature:eclipse.feature$5.0.0.qualifier#site.p2]
[end xxx.product.feature:eclipse.feature$5.0.0.qualifier#site.p2]
[start xxx.product.feature:eclipse.feature$5.0.0.qualifier#create.product]
[ant] /tmp/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
[ant] file:/tmp/buckminster/build/xxx.product.feature_5.0.0-eclipse.feature/site.p2/
[ant] /tmp/buckminster/build/xxx.product.feature_5.0.0-eclipse.feature/mmt-rcp.gtk.linux.x86_64
[end xxx.product.feature:eclipse.feature$5.0.0.qualifier#create.product]
What is the meaning of this message and how can I fix it?
Thanks in advance!
[Updated on: Sat, 02 March 2013 00:05] Report message to a moderator
Re: Error message: Cannot determine filter for requirement to this element [message #1014634 is a reply to message #1014516] |
Tue, 26 February 2013 07:39   |
by googling, it looks like they have a similar problem with tycho: in
that case the problem happens, as far as I understand, when you build
the site of a feature which refers to another feature using the version
with the qualifier...
is that your case?
cheers
Lorenzo
On 02/26/2013 01:44 AM, Lothar Werzinger wrote:
> I am getting this peculiar error message with buckminster:
> Quote:
>> publishing result
> I can see
> Quote:
>> ls
> Thanks in advance!
HOME: http://www.lorenzobettini.it
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: Error message: Cannot determine filter for requirement to this element [message #1015753 is a reply to message #1015735] |
Sat, 02 March 2013 08:48   |
On 03/02/2013 01:08 AM, Lothar Werzinger wrote:
> Lorenzo Bettini wrote on Fri, 01 March 2013 08:38
>> an easier approach is to follow the steps found here
>> http://wiki.eclipse.org/Extending_or_Contributing_to_Buckminster#Prepare_an_empty_target_platform
>> however, if you still have problems in the IDE, could you share the
>> project or is it closed source?
> That's more or less the same steps I use to create the TP.
> Unfortunately I can't share the project.
> I double verified that the problem occurs only in the Kepler IDE and not
> in the Juno IDE.
> I updated the original post to reflect that.
I tried with Kepler myself, and experience exactly the same problem,
with this example
http://sourceforge.net/p/buckyexamples/bucky-mail-rcp/
apparently, running site.p2 action in the IDE on a feature project
containing a product configuration or including a feature which in turns
contains a product configuration (e.g., in the example above, on the
project org.eclipse.buckminster.examples.rcp.mail.product.site) leads to
this error...
the strange thing is that the site.p2 is actually created correctly...
could it be that the installed buckminster is built against Juno?
Thomas?
cheers
Lorenzo
Re: Error message: Cannot determine filter for requirement to this element [message #1015758 is a reply to message #1015753] |
Sat, 02 March 2013 10:09   |
I suggest that you enter a bugzilla for this. Mention how to build using
the example so that it succeeds and so that it fails. That will make it
easy to track down. I don't have any good guesses.
- thomas
>> in the Juno IDE.
> Hi
> with this example
> this error...
> Thomas?
> cheers
> Lorenzo
Re: Error message: Cannot determine filter for requirement to this element [message #1015823 is a reply to message #1015758] |
Sun, 03 March 2013 09:13   |
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=402230
hope I provided enough information
cheers
Lorenzo
> - thomas
>>> in the Juno IDE.
>> Hi
>> with this example
>> this error...
>> Thomas?
>> cheers
>> Lorenzo
Re: Error message: Cannot determine filter for requirement to this element [message #1258539 is a reply to message #1105028] |
Thu, 27 February 2014 13:39  |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Hi guys,
I actually hit this one. For some weird reason I could not find bucky in the Kepler Simultaneous Release P2 site, so went to the bucky eclipse.org download page (http://www.eclipse.org/buckminster/downloads.html) which seems not updated, so I ended up using 1.5.0 on my Kepler 4.3.1 workbench, which lead to this issue.
I found this bug, uninstalled bucky 1.5.0, and finally found the 1.6.0 release published at http://download.eclipse.org/tools/buckminster/updates-4.3, and everything worked.
It's weird because this issue did not use to happen in our jenkins/bucky 4.2 CI machine.
Also don't forget to clear .metadata/org.eclipse.buckminster.core cache from time to time, specially when switching versions. I actually had a whole lot of different issues due to inconsistent data in that folder.
Best Regards,
Víctor Roldán [Open Canarias]
Current Time: Thu Mar 30 12:42:43 GMT 2023
Powered by FUDForum. Page generated in 0.02273 seconds
