Home » Archived » BIRT » Graphic series interrvals
Graphic series interrvals [message #1014374] Mon, 25 February 2013 17:26 Go to next message
Mimmo Rossi is currently offline Mimmo RossiFriend
i seen that there is a possibility to set step of a series, but there is a possibility to set intervals?
That is to say, i would have this:
series 1= 0 - 2 - 4 - 6 - 8
series 2= 0.2 - 3.6 - 3.9 - 5.7 - 8
that is to say i would have two equal intervals of 5 elements.
Thanks in advance
Re: Graphic series interrvals [message #1014401 is a reply to message #1014374] Mon, 25 February 2013 18:50 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
I'm not sure I'm completely understanding. Could you explain this in a little more detail?
Michael
Developer Evangelist, Silanis
Re: Graphic series interrvals [message #1014798 is a reply to message #1014401] Tue, 26 February 2013 13:36 Go to previous messageGo to next message
In this chart:
https://dl.dropbox.com/u/47586998/img.JPG
the series on the left has a series with 6 values, i would that also the series on the right has 6 values.
Re: Graphic series interrvals [message #1014909 is a reply to message #1014798] Tue, 26 February 2013 18:13 Go to previous messageGo to next message
Are the ranges going to be dynamic or static?
Michael
Re: Graphic series interrvals [message #1015040 is a reply to message #1014909] Wed, 27 February 2013 09:29 Go to previous messageGo to next message
I would that the series 2 have the same intervals of series 1, so dynamic is better, but also static might be ok.
Re: Graphic series interrvals [message #1015288 is a reply to message #1015040] Thu, 28 February 2013 04:17 Go to previous messageGo to next message
If your values will always be in a particular range, for both series, you'd be able to set these intervals within the chart editor. If the values will be dynamic, for example the first series can be more than 6 or the second series can be less than 3.9 or greater than 4.8. I think based off your original post, this is the case. What you'd need to do here, is use the afterDataSetFilled script to find the min and max values for each series. Then, in the beforeGeneration, set the axis min, max, and step.
Michael
Re: Graphic series interrvals [message #1015393 is a reply to message #1015288] Thu, 28 February 2013 13:18 Go to previous messageGo to next message
Hy Michael,
i already do so, I thought there was a faster way.
Thanks anyway
Re: Graphic series interrvals [message #1015478 is a reply to message #1015393] Thu, 28 February 2013 16:48 Go to previous message
You're welcome. Sorry I wasn't able to give a quicker way!
Michael
Previous Topic:How to set the name of output exel file (differ than the name of rptdesign file)?
Next Topic:Logging for WebViewerExample
Current Time: Tue Apr 16 09:33:30 GMT 2024
Powered by FUDForum. Page generated in 1.66920 seconds
