Re: Execute system Groovy script not working with Hudson 3.0 [message #1111268 is a reply to message #1111257] |
Wed, 18 September 2013 02:08 |
Carlton Brown Messages: 2 Registered: September 2013 |
Winston Prakash wrote on Tue, 17 September 2013 21:45Hi Carlton, I wasn't able to reproduce this on Hudson 3.0.0. However, when I tried to build the groovy builder plugin with 3.0.1-b2, I noticed it wouldn't build because it uses older version of plexus-utils because we switched to use latest Plexus jars in 3.0.1-b2 to support JDK 7. Anyway, I was able to verify it works fine on Hudson 3.0.1-b2 (See the screenshots below). Can you test with my developer build
Hi Winston, thanks for looking into it. I saw the same stacktrace after removing the existing groovy plugin, installing the developer build, and restarting Hudson. Please let me know if you have any further ideas.
My JDK info is -
java version "1.7.0_25"
Java(TM) SE Runtime Environment (build 1.7.0_25-b15)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
FUDForum. Page generated in 0.02695 seconds
