Home » Modeling » GMF (Graphical Modeling Framework) » determine creation source of elements
determine creation source of elements [message #1014229] Mon, 25 February 2013 12:05 Go to next message
Chris B. is currently offline Chris B.Friend
Member
is it possible to find out whether an element is created from the palette or the context menu while dragging it?
Chris
Re: determine creation source of elements [message #1014631 is a reply to message #1014229] Tue, 26 February 2013 07:32 Go to previous messageGo to next message
Thomas Beyer is currently offline Thomas BeyerFriend
Member
Hi Chris,
what exactly do you mean by Quote:
? The Popup Handles on the diagram elements?
Thomas
Re: determine creation source of elements [message #1015063 is a reply to message #1014631] Wed, 27 February 2013 10:52 Go to previous message
Ralph Gerbig is currently offline Ralph GerbigFriend
GraphicalNodeEditPolicy is responsible for showing this context menu. You could add information to the request's map used to store parameters. This you could check in your creation command and execute code depending on this value. Is this what you intend to do? If yes I can give you further details, methods to modiy, installing a custom graphical node edit policy etc.
Ralph
Previous Topic:Dependencies to externalize a plugin
Next Topic:GMF examples sources
Current Time: Sun May 31 02:15:06 GMT 2020
Powered by FUDForum. Page generated in 0.02167 seconds
