Home » Modeling » Papyrus » Papyrus Kepler version doesn't support Palette customization
Papyrus Kepler version doesn't support Palette customization [message #1014175] Mon, 25 February 2013 09:53 Go to next message
Walid Ban is currently offline Walid BanFriend
Member
when i imported the plugins of my palettes, an error msg appears in the "problem window". here are they:
Description Resource Path Location Type
Unknown extension point: 'org.eclipse.papyrus.diagram.common.paletteDefinition' plugin.xml /org.eclipse.AWSUseCaseDiag.Palette line 5 Plug-in Problem
Bundle 'org.eclipse.papyrus.diagram.common' cannot be resolved MANIFEST.MF /org.eclipse.AWSUseCaseDiag.Palette/META-INF line 9 Plug-in Problem
I don't know if you met this bug before!?
regards
Re: Papyrus Kepler version doesn't support Palette customization [message #1014352 is a reply to message #1014175] Mon, 25 February 2013 16:37 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Did you try to migrate directly from Indigo (0.8.X) to Kepler (0.10.X) ? This error should occur on Juno (0.9.X) too.
In Juno, the ID of papyrus.diagram.common has been changed to papyrus.uml.diagram.common, to improve naming consistency in Papyrus. Major changes in the namespaces have occurred in Juno (Papyrus 0.9). However, it should be consistent between Juno and Kepler.
Camille
Camille Letavernier
Re: Papyrus Kepler version doesn't support Palette customization [message #1014404 is a reply to message #1014352] Mon, 25 February 2013 18:59 Go to previous messageGo to next message
Member
Hi, I just downloaded Eclipse Modeling tools Kepler and then install Papyrus 0.10 from:
http://www.eclipse.org/downloads/download.php?file=/modeling/mdt/papyrus/downloads/drops/0.10.0/N201302180813/Papyrus-Update-N201302180813.zip
When i wanted to export and install my Palette plugin, an error message appears and tell me that the extension point is unknown.
What should i do?
Re: Papyrus Kepler version doesn't support Palette customization [message #1014415 is a reply to message #1014404] Mon, 25 February 2013 19:24 Go to previous messageGo to next message
As a minimum you should tell us what the error message says.
Ed Willink
> Papyrus 0.10 from:
> What should i do?
Re: Papyrus Kepler version doesn't support Palette customization [message #1014462 is a reply to message #1014415] Mon, 25 February 2013 21:48 Go to previous messageGo to next message
Member
As Camille said, i just must change the Papyrus Id.
1) I delete the plugin "org.eclipse.papyrus.diagram.common" in the Dependency tab
2) Add the plugin "org.eclipse.papyrus.UML.diagram.common"
3) delete the extension point "org.eclipse.papyrus.diagram.common.paletteDefinition"
4) Add the extension point "org.eclipse.papyrus.UML.diagram.common.paletteDefinition"
5) Complete the Extension details ( just the class will be changed--> "org.eclipse.papyrus.UML.diagram.common.service.PluginPaletteProvider")
BUT!!! when i launched the palette plugin and create a new papyrus project, for example, My custom class diagram platte doesn't appear after applying the profile on the model Confused I don't know?
Do you have any idea please?
Re: Papyrus Kepler version doesn't support Palette customization [message #1014632 is a reply to message #1014462] Tue, 26 February 2013 07:33 Go to previous messageGo to next message
HI
Most of what you have described should have been identified by warning
markers. How many other warnings are you ignoring?
If you are changing id's are you absolutely sure that you have changed
all of them consistently? It is very easy to miss one, particularly
amongst a mix of Java/XML references.
Do a diff of your changes then search your entire source for all
references to each of the changed id's.
Ed Willink
On 25/02/2013 21:48, Walid Ban wrote:
> As Camille said, i just must change the Papyrus Id. 1) I delete the
> after applying the profile on the model :? I don't know? Do you have
> any idea please?
Re: Papyrus Kepler version doesn't support Palette customization [message #1014677 is a reply to message #1014632] Tue, 26 February 2013 09:12 Go to previous messageGo to next message
The palette.xml file contains the ID of the diagram the palette applies to. You need to change this ID too, as most diagram IDs have changed in 0.9.X too.
Camille
Camille Letavernier
Re: Papyrus Kepler version doesn't support Palette customization [message #1014681 is a reply to message #1014632] Tue, 26 February 2013 09:17 Go to previous messageGo to next message
Member
I changed the ID of the Editor (e.g org.eclipse.papyrus.UML.diagram.clazz) and it worked! Thank you
But something weard i've seen, i have a custom palette for the UseCase diagram, when i drag an stereotyped actor(because it's from my palette), the stereotype dosn't appear! It isn't even applied to the actor! (I checked "profile" in the property window!)
Here is a capture: index.php/fa/13549/0/
but it works normally with the use cases. Well, i'm surprised.
Do you have an explanation to that?
  • Attachment: useCase.png
    (Size: 134.21KB, Downloaded 2420 times)
Re: Papyrus Kepler version doesn't support Palette customization [message #1014685 is a reply to message #1014681] Tue, 26 February 2013 09:24 Go to previous messageGo to next message
A few questions:
- Can you apply your profile manually and apply your stereotypes?
- Did you check the stereotype IDs/Qualified names in your palette definition?
Camille
Camille Letavernier
Re: Papyrus Kepler version doesn't support Palette customization [message #1014743 is a reply to message #1014685] Tue, 26 February 2013 11:33 Go to previous messageGo to next message
Member
- Yes i can apply the profile on the model and i can apply the stereotypes on Actors. But, even the stereotype is applied on an actor, nothing special happen! it's like i'm creating a normal Actor. I checked the "appearance" in the "apperance window", it's ok!
- I think nothing is wrong with the palette XML file, it's attached.
Don't forget that it works for the use cases, the sterotype is automatically applied when i drag a use case from my palette.
icon5.gif  Re: Papyrus Kepler version doesn't support Palette customization [message #1028636 is a reply to message #1014685] Thu, 28 March 2013 14:36 Go to previous message
Member
Well I can apply a stereotype on an actor and the stereotype was shown when i changed the Display place from "Compartment" to "With Brace". But what I didn't understand is:
Why a stereotype(for an Actor) can't be automatically applied on an actor when i drag it from my palette?! And at the same time, a stereotype (for a Use Case) can be applied automatically on a Use Case when i drag it from my Palette!!?
The automatic application of a stereotype works for use cases, classes, life lines,.. but not for Actors! That's really weard.
Could you help me please?
Best regards
Previous Topic:The default value"unbounded" of an attribute
Next Topic:Stereotype Appearance
Current Time: Tue Apr 16 15:39:13 GMT 2024
Powered by FUDForum. Page generated in 0.49247 seconds
