Home » Eclipse Projects » Hudson » Hudson doesn't start on Oracle linux
Hudson doesn't start on Oracle linux [message #1013027] Fri, 22 February 2013 16:16 Go to next message
muhammed soyer is currently offline muhammed soyerFriend
I downloaded hudson-3.0.0-1.1.noarch.rpm and installed it on an Oracle linux. But when I restart the server I see that it is holding while starting Hudson.
When I try from command line same happens ..
What might be wrong ? I says Starting Hudson and doesn't move ..
/etc/init.d/hudson start
Starting Hudson
Re: Hudson doesn't start on Oracle linux [message #1013052 is a reply to message #1013027] Fri, 22 February 2013 17:16 Go to previous message
Winston Prakash is currently offline Winston PrakashFriend
An issue was found and it is discussed in the thread http://www.eclipse.org/forums/index.php/t/446623/
Please edit /etc/init.d/hudson
and change
daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS > /dev/null
to
daemon --user "$HUDSON_USER" --pidfile "$HUDSON_PID_FILE" $JAVA_CMD $PARAMS &> /var/tmp/hudson.log &
After this any log message can be found at /var/tmp/hudson.log
Winston Prakash
Eclipse Hudson team
Previous Topic:SVN externals no longer trigger SCM Polling builds
Next Topic:Migration to 3.0 - thinBackup problem
Current Time: Sat Dec 05 18:04:40 GMT 2020
Powered by FUDForum. Page generated in 0.01540 seconds
