Xtext: Couldn't resolve reference to JvmType 'String' [message #1012559] |
Thu, 21 February 2013 19:45 |
Dustin Steiner Messages: 10 Registered: October 2012 |
I already posted it on Stackoverflow but was hoping to reach more experts here
For our master project at university we created multiple DSLs using Xtext. One of the DSLs is a model entity DSL which allows the user to create a class with properties and methods.
We reuse Xbase because, of course, we want the methods to have a real programming language without reinventing the wheel:
grammar ... with org.eclipse.xtext.xbase.Xbase
generate ...
EntityModel:
'package' importedNamespace=QualifiedName
implementation=Entity;
Entity:
'entity' name=ValidID '{'
features+=Feature*
Feature:
LocalVariable | ...;
LocalVariable:
'var' (isStatic?='static')? name=ValidID ':' type=JvmTypeReference;
For some reason, even though the type of the LocalVariable is set to JvmTypeReference, when using String (in an actual implementation), it will always show the error
Quote:Xtext: Couldn't resolve reference to JvmType 'String'
package com.example
Entity foo {
var bar: String
We already tried using a ImportedNamespaceAwareLocalScopeProvider which in getImportedNamespaceResolvers adds java.lang.* like that:
List<ImportNormalizer> implicitImports = super.getImportedNamespaceResolvers(context, ignoreCase);
List<ImportNormalizer> javaLangImports = singletonList(new ImportNormalizer(QualifiedName.create("java", "lang"), true, ignoreCase));
implicitImports.addAll(javaLangImports);
return implicitImports;
Even thought that method is called a lot of times, the imports still don't work. When inspecting the EObject context parameter, it sometimes returns java.lang.String (which I guess is for the JvmTypeReference but it still displays an error.
In the RuntimeModule the new scope provider is configured like that:
public void configureIScopeProviderDelegate(com.google.inject.Binder binder) {
binder.bind(org.eclipse.xtext.scoping.IScopeProvider.class).annotatedWith(com.google.inject.name.Names.named(org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(MasterDSLImportedNamespaceAwareLocalScopeProvider.class);
In the Workflow we configured
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
fragment = xbase.XbaseGeneratorFragment {}
fragment = types.TypesGeneratorFragment {}
The rest of the project is quite complex already (4 Xtext DSLs in one project and multiple generators). But except for completely different DSLs, they use almost the same workflow and RuntimeModule configuration. Another DSL also uses JvmTypeReference and also doesn't find e.g. boolean or anything else.
The question of course is: are we doing something wrong or is there something else we have to do. It used to work when we had a significantly smaller project but after some major changes suddenly this stopped working.
The model implementations (*.model) can be highlighted and everything but those imports just won't work
Also, some parts of XExpression (like !=) are highlighted as not being recognized from the parser.
FUDForum. Page generated in 0.04373 seconds
