Home » Modeling » Epsilon » AbstractEmfModel#store exception due to unmapped path
AbstractEmfModel#store exception due to unmapped path [message #13728] |
Tue, 10 March 2009 16:45 |
Louis Rose Messages: 440 Registered: July 2009 Location: York, United Kingdom |
When using AbstractEmfModel#store, I receive an IOException due to an
unmapped path.
I'm running Epsilon from source, and calling store from a runtime
workspace. Here's my code:
http://pastie.org/412896
save is the name of my project, and test.model is the resource that I
would like to be written.
I receive the following stack trace:
java.io.IOException: The path '/save/out.model' is unmapped
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl.createOutputStream(PlatformResourceURIHandlerImpl.jav a:424)
at
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createOutputStream(ExtensibleURIConverterImpl.java:290)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:983)
at
org.eclipse.epsilon.emc.emf.AbstractEmfModel.store(AbstractE mfModel.java:464)
at save.Test.main(Test.java:16)
Is the filename passed to store wrong?
Louis.
Louis Rose
Research Student
Department of Computer Science,
University of York,
Heslington, York, YO10 5DD, United Kingdom.
+44 1904 434762
Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #13751 is a reply to message #13728] |
Wed, 11 March 2009 09:17 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Louis,
I tried this code from a runtime workbench (a test button in a test
view) and it worked. On the other hand, when I tried it from a main
method it failed with the error you see too. The reason is that
"save/out.model" is resolved to "platform:/resource/save/out.model"
which when you are running a "main" is not mapped.
Dimitris
Louis Rose wrote:
> unmapped path.
> at
> at
> at
> at
> Cheers,
> Louis.
> Louis Rose
> Research Student
> University of York,
> +44 1904 434762
> Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #13771 is a reply to message #13751] |
Wed, 11 March 2009 09:43 |
I see, that makes sense. I guess I'll see if I can find a way to map my
projects. (I'm not really running a main method; I'm running jUnit tests).
A somewhat related issue: I've also found that I can't create an
(Epsilon) EMF Model using the Epsilon perspective. I receive the
following exception.
It looks like Epsilon is using a mixture of platform and file URI. I'm
not sure which it should be using in this case. (/Users is a top-level
directory on my machine).
platform:/resource/Users/louis/Code/eclipse/workspaces/runti me-epsilon/gadin.actions.model/model/test.model
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
'/Users' does not exist.
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$PlatformResourceOutputStream.createContainer(Platform ResourceURIHandlerImpl.java:81)
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$PlatformResourceOutputStream.createContainer(Platform ResourceURIHandlerImpl.java:74)
at
at
at
at
at
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$PlatformResourceOutputStream.flush(PlatformResourceUR IHandlerImpl.java:108)
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$PlatformResourceOutputStream.close(PlatformResourceUR IHandlerImpl.java:90)
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$WorkbenchHelper$1.close(PlatformResourceURIHandlerImp l.java:172)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:990)
at org.eclipse.epsilon.emc.emf.EmfModel.store(EmfModel.java:231 )
at
org.eclipse.epsilon.util.emf.NewEmfModelWizard.doFinish(NewE mfModelWizard.java:148)
at
org.eclipse.epsilon.util.emf.NewEmfModelWizard.access$0(NewE mfModelWizard.java:117)
at
org.eclipse.epsilon.util.emf.NewEmfModelWizard$1.run(NewEmfM odelWizard.java:91)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Caused by: org.eclipse.core.internal.resources.ResourceException:
Resource '/Users' does not exist.
at
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:317)
at
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:194)
at
org.eclipse.core.internal.resources.Project.checkAccessible( Project.java:113)
at
org.eclipse.core.internal.resources.Folder.assertCreateRequi rements(Folder.java:32)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:88)
at org.eclipse.core.internal.resources.Folder.create(Folder.jav a:118)
at
org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandl erImpl$PlatformResourceOutputStream.createContainer(Platform ResourceURIHandlerImpl.java:77)
... 15 more
Dimitris Kolovos wrote:
> Hi Louis,
> Cheers,
> Dimitris
> Louis Rose wrote:
>> Hi,
>> unmapped path.
>> at
>> at
>> at
>> at
>> Cheers,
>> Louis.
>> Louis Rose
>> Research Student
>> University of York,
>> +44 1904 434762
>> Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #13791 is a reply to message #13771] |
Wed, 11 March 2009 10:09 |
Adding the following before calling store works:
EcorePlugin.getPlatformResourceMap().put("save",
URI.createFileURI("/Users/louis/Code/eclipse/workspaces/runtime-epsilon/save/ "));
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #14422 is a reply to message #13771] |
Wed, 18 March 2009 13:40 |
Hi Louis,
Thanks for reporting this. I've fixed it and committed the changes to
the SVN.
Dimitris
Louis Rose wrote:
<snip>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
>> Hi Louis,
>> Cheers,
>> Dimitris
>> Louis Rose wrote:
>>> Hi,
>>> unmapped path.
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Louis.
>>> Louis Rose
>>> Research Student
>>> University of York,
>>> +44 1904 434762
>>> Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #565935 is a reply to message #13728] |
Hi Louis,
Dimitris
Louis Rose wrote:
> unmapped path.
> at
> at
> at
> at
> Cheers,
> Louis.
> Louis Rose
> Research Student
> University of York,
> +44 1904 434762
> Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #565959 is a reply to message #13751] |
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 15 more
> Hi Louis,
> Cheers,
> Dimitris
> Louis Rose wrote:
>> Hi,
>> unmapped path.
>> at
>> at
>> at
>> at
>> Cheers,
>> Louis.
>> Louis Rose
>> Research Student
>> University of York,
>> +44 1904 434762
>> Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #565982 is a reply to message #13771] |
Louis.
Louis Rose
Research Student
University of York,
+44 1904 434762
Twitter: @louisrose
Re: AbstractEmfModel#store exception due to unmapped path [message #566067 is a reply to message #13771] |
Hi Louis,
the SVN.
Dimitris
Louis Rose wrote:
<snip>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
>> Hi Louis,
>> Cheers,
>> Dimitris
>> Louis Rose wrote:
>>> Hi,
>>> unmapped path.
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Louis.
>>> Louis Rose
>>> Research Student
>>> University of York,
>>> +44 1904 434762
>>> Twitter: @louisrose
Current Time: Thu Apr 25 16:07:49 GMT 2024
Powered by FUDForum. Page generated in 0.03828 seconds
