Diagram not navigable in Kepler [message #1012338] |
Thu, 21 February 2013 11:26 |
Hi Team,
just gave a fist test on Kepler M5 and Papyrus Nightly (19th February).
I was not able to open a diagram (neither via double-click nor via context
menu) from the ModelExplorer.
I was also not able to navigate from a an element in a diagram to a linked
diagram via the plus button. I could specify the link properply, but the
diagram was not opened.
There was even no error trace logged!
Marc-Florian
Re: Diagram not navigable in Kepler [message #1012358 is a reply to message #1012349] |
Thu, 21 February 2013 12:08 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hello Marc-Florian and Ed,
I'm currently working on the major Papyrus-page issues. Current status is, on the nightly build:
- Creating, opening, navigating, deleting, ... pages works correctly
- Deleting an element which "contains" an opened diagram still leads to model corruption. See Bug 401109
- Programmatically changing the "active page" (i.e. active tab) does not work yet. See Bug 401107. Consequently, it is not possible to navigate an hyperlink to a page which is already opened (In the previous versions of Papyrus, it used to re-open the page)
So... I'm actually quite surprised that you cannot perform these actions. The only thing that could still cause this issue would be a partially-corrupted model (e.g. you're trying to open a diagram which is not in the list of "available pages" in the DI model... This should not happen anymore, but it might be the case for diagrams created in previous versions of Papyrus).
Camille
Camille Letavernier
Re: Diagram not navigable in Kepler [message #1013115 is a reply to message #1012358] |
Fri, 22 February 2013 20:17 |
Hi Camille,
yes, thanks for pointing this out. In fact, I did not tried if a diagram
that is not open will be opened and get the focus. So, this scenario works
nice. If a diagram is closed, it will be opened and be activated.
As you said, switching to an already opened diagram does not work, neither
from the ModelExplorer nor from the hyperlink.
I WILL NOT file a bug, since it is already filed and such a fundamental
thing, I guess this will be fixed soon.
Marc-Florian
"Camille Letavernier" schrieb im Newsbeitrag
news:kg52nd$l9f$1@xxxxxxxxe.org...
model corruption. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=401109
work yet. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=401107.
page)
of Papyrus).
Camille
FUDForum. Page generated in 0.03474 seconds
