Home » Eclipse Projects » BIRT » Some columns are not exported in Excel
Some columns are not exported in Excel [message #1011845] Wed, 20 February 2013 11:00 Go to next message
Reshma Joshi is currently offline Reshma JoshiFriend
I am new to BIRT report and created my first complex report. It is running successfully. but when i say Export Report and choose Excel, BIRT is skipping two columns and displaying data in Excel format. These two columns are simply coming from data set and these are not calculated ones. I am not getting why these two columns are getting skipped.
I searched this forum and found that if you give different width to columns it may create problems. Hence I changed all my column widths to have default BIRT values but still it is skipping these two columns. Surprisingly its showing other columns which are calculated ones.
Please this is really urgent and help is appreciated.
Re: Some columns are not exported in Excel [message #1012096 is a reply to message #1011845] Wed, 20 February 2013 21:43 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Can you recreate the issue with the sample database? If not, can you at least attach your design and let me know which columns aren't showing up in XLS. Thanks.
Michael
Developer Evangelist, Silanis
Previous Topic:HowTo sum (accumulate) aggregate values in chart BIRT Eclipse
Next Topic:source code of org.eclipse.birt.report.engine.source_4.2.1.v20120820\
Current Time: Wed Dec 08 07:21:56 GMT 2021
Powered by FUDForum. Page generated in 0.02151 seconds
