Home » Eclipse Projects » GEF » CellEditor tutorial
CellEditor tutorial [message #147121] |
Tue, 10 August 2004 17:53  |
Originally posted by: svenkat.asu.edu
I want to be able to click on nodes and add text entries, much like that of
a UML Class node. I understand from reading the archives that I would be
using DirectEdit and CellEditor. I was wondering if there was any article
or tutorial on how I can get a start on making a node editable.
Thanks.
Re: CellEditor tutorial [message #147143 is a reply to message #147121] |
Tue, 10 August 2004 18:56   |
Basically, you just receive the DirectEditRequest, startup a
DirectEditManager, and provide the command which performs the edit in the
end. You may also provide optional feedback. See LabelDirectEditPolicy in
logic example.
"Swami Venkataramani" <svenkat@asu.edu> wrote in message
news:cfb2kv$tmc$1@eclipse.org...
of
> Thanks.
Re: CellEditor tutorial [message #147660 is a reply to message #147143] |
Fri, 13 August 2004 23:55   |
For some reason, I am not able to get the cell editor to show up:
I copied stuff from the Logic example:
1. I added the following methods in my edit part:
protected void createEditPolicies()
installEditPolicy(EditPolicy.COMPONENT_ROLE, new
FilterEditPolicy());
installEditPolicy(EditPolicy.NODE_ROLE, new
SFTEditGraphicalNodeEditPolicy());
installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE, null);
installEditPolicy(EditPolicy.DIRECT_EDIT_ROLE, new
LabelDirectEditPolicy());
//installEditPolicy(EditPolicy.COMPONENT_ROLE,new
LogicLabelEditPolicy());
private void performDirectEdit(){
if(manager == null)
manager = new LogicLabelEditManager(this,
TextCellEditor.class, new
LabelCellEditorLocator((StickyNoteFigure)getFigure()));
manager.show();
public void performRequest(Request request){
if (request.getType() == RequestConstants.REQ_DIRECT_EDIT)
performDirectEdit();
Then, I added the following classes:
1. LabelDirectEditPolicy
2. LogicLabelCommand
3. LabelCellEditorLocator
4. LogicLabelEditManager
(All exactly as it is in the Logic Example)
My createFigure in the editPart looks like this (StickyNoteFigure in my
program simply extends ImageFigure and has the same methods as the one on
the logic example):
protected IFigure createFigure()
Image andGate = new Image (null,
"C:/eclipse/workspace/sft/src/sft/editor/images/andGate.bmp");
StickyNoteFigure gate = new StickyNoteFigure();
gate.setImage(andGate);
Label label = new Label(label_);
label.setLocation(new Point(0,0));
gate.add(label);
Point location = new Point(60,50);
gate.setLocation(location);
gate.setSize(new Dimension(70,70));
return gate;
protected void refreshVisuals()
NodeModel node = (NodeModel)getModel();
StickyNoteFigure gate = (StickyNoteFigure)getFigure();
Point p = node.getLocation();
Dimension s = node.getSize();
Rectangle r = new Rectangle(p, s);
((GraphicalEditPart) getParent()).setLayoutConstraint(this, gate,
r);
super.refreshVisuals();
What am I missing?
Thanks for any help...
Swami.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cfb5jk$28t$1@eclipse.org...
> in
> logic example.
> of
>> article
>> Thanks.
Re: CellEditor tutorial [message #147715 is a reply to message #147660] |
Mon, 16 August 2004 14:32   |
Did you create the action and place it in a Menu or somewhere where you
could invoke it?
news:cfjkvk$vok$1@eclipse.org...
> if(manager == null)
> manager.show();
> the logic example):
> gate.add(label);
> return gate;
> r);
> What am I missing?
> Swami.
the
> > in
> > logic example.
that
> > of
be
> >> article
> >> Thanks.
Re: CellEditor tutorial [message #147769 is a reply to message #147715] |
Mon, 16 August 2004 17:33   |
Basically, I wanted my user to click once on my edit part, which will then
open up a text editor (just like the Label in the Logic example). Do I need
to create an Action and place it in a Menu for this? I thought the action
would be to simply click on the edit part. Sorry, I'm still a newbie :-)
Swami.
news:cfqgce$pe$1@eclipse.org...
> could invoke it?
>> if(manager == null)
>> manager.show();
>> the logic example):
>> gate.add(label);
>> return gate;
>> r);
>> What am I missing?
>> Swami.
> the
>> > in
>> > logic example.
> that
>> > of
> be
>> >> article
>> >> Thanks.
Re: CellEditor tutorial [message #147776 is a reply to message #147769] |
Mon, 16 August 2004 17:35   |
Nope, your right. You need to click on the part to select it, then click a
second time to direct-edit the same part. This is how the "platform" (read
windows file explorer) works.
news:cfqqvq$jro$1@eclipse.org...
need
> Swami.
> > could invoke it?
> >> if(manager == null)
> >> manager.show();
on
> >> the logic example):
> >> gate.add(label);
> >> return gate;
gate,
> >> r);
> >> What am I missing?
> >> Swami.
> > the
> >> > in
> >> > logic example.
> > that
> >> > of
would
> > be
> >> >> article
> >> >> Thanks.
Re: CellEditor tutorial [message #147784 is a reply to message #147776] |
Mon, 16 August 2004 18:14   |
That doesn't work however--when I select the edit part and then click it
once more, I thought the editor should pop up--but it doesn't...so I was
wondering what I was missing, because like I was describing in my earlier
mails, most of my components are ditto to the Logic example...
Any suggestions?
Swami.
news:cfqr4n$k40$1@eclipse.org...
> a
> (read
>> then
> need
>> action
>> Thanks,
>> Swami.
>> > could invoke it?
>> >> if(manager == null)
>> >> manager.show();
>> >> my
> on
>> >> the logic example):
>> >> gate.add(label);
>> >> return gate;
> gate,
>> >> r);
>> >> What am I missing?
>> >> Swami.
>> >> > in
>> > the
>> >> > in
>> >> > logic example.
>> > that
>> >> > of
> would
>> > be
>> >> >> article
>> >> >> Thanks.
Re: CellEditor tutorial [message #147802 is a reply to message #147784] |
Mon, 16 August 2004 19:58   |
put a breakpoint in SelectEditPartTracker.handleButtonUp(). The
performDirectEdit() method should get called, step into it and find out
where it stops.
news:cfqtdb$nm7$1@eclipse.org...
> Any suggestions?
> Swami.
click
> > a
> > (read
> >> then
> > need
> >> action
> >> Thanks,
> >> Swami.
you
> >> > could invoke it?
> >> >> if(manager == null)
> >> >> manager.show();
> >> >> my
one
> > on
> >> >> the logic example):
> >> >> gate.add(label);
> >> >> return gate;
> > gate,
> >> >> r);
> >> >> What am I missing?
> >> >> Swami.
> >> >> > in
> >> > the
> >> >> > in
> >> >> > logic example.
like
> >> > that
> >> >> > of
> > would
> >> > be
any
> >> >> >> article
> >> >> >> Thanks.
Re: CellEditor tutorial [message #147833 is a reply to message #147802] |
Tue, 17 August 2004 02:37   |
Ok, here is the code where I observed as you had asked me to:
protected boolean handleButtonUp(int button) {
if (isInState(STATE_DRAG)) {
performSelection();
if (getFlag(FLAG_ENABLE_DIRECT_EDIT))
if (button == 1 && getSourceEditPart().getSelected() !=
EditPart.SELECTED_NONE)
getCurrentViewer().reveal(getSourceEditPart());
setState(STATE_TERMINAL);
return true;
return false;
I steped over each line when the control came into this method...it returned
from performDirectEdit and then later stops debugging when it reaches the
folowing method in Workbench:
private void runEventLoop(Window.IExceptionHandler handler, Display display)
runEventLoop = true;
while (runEventLoop) {
try {
if (!display.readAndDispatch()) {
getAdvisor().eventLoopIdle(display);
} catch (Throwable t) {
handler.handleException(t);
The program doesn't halt or anything--I can continue to drag further objects
from my pallete, but the direct edit editor does not show up when the edit
part is clicked.
news:cfr3g2$2et$1@eclipse.org...
> where it stops.
>> Any suggestions?
>> Thanks,
>> Swami.
> click
>> > a
>> > (read
>> >> then
>> >> I
>> > need
>> >> action
>> >> Thanks,
>> >> Swami.
> you
>> >> > could invoke it?
>> >> >> if(manager == null)
>> >> >> manager.show();
>> >> >> in
>> >> >> my
> one
>> > on
>> >> >> the logic example):
>> >> >> gate.add(label);
>> >> >> return gate;
>> > gate,
>> >> >> r);
>> >> >> What am I missing?
>> >> >> Swami.
>> >> >> > edit
>> >> >> > in
>> >> > the
>> >> >> > in
>> >> >> > logic example.
> like
>> >> > that
>> >> >> > of
>> > would
>> >> > be
> any
>> >> >> >> article
>> >> >> >> Thanks.
Re: CellEditor tutorial [message #147896 is a reply to message #147833] |
Tue, 17 August 2004 14:30   |
You've stepped through to the event loop of the application where it waits
for Windows to send more message. You need to step Into (F5)
performDirectEdit(), and step into editpart.performRequest(), etc., and find
out if your editpart is receiving the request, if it constructs a
celleditor, if it is actived, etc.
news:cfrqs0$vh6$1@eclipse.org...
> performSelection();
> return true;
> return false;
returned
display)
> try {
objects
> part is clicked.
> > where it stops.
it
was
earlier
> >> Any suggestions?
> >> Thanks,
> >> Swami.
> > click
> >> > a
> >> > (read
will
> >> >> then
Do
> >> >> I
> >> > need
> >> >> action
> >> >> Thanks,
> >> >> Swami.
where
> > you
> >> >> > could invoke it?
up:
> >> >> >> if(manager == null)
> >> >> >> manager.show();
> >> >> >> in
> >> >> >> my
the
> > one
> >> > on
> >> >> >> the logic example):
> >> >> >> gate.add(label);
> >> >> >> return gate;
> >> > gate,
> >> >> >> r);
> >> >> >> What am I missing?
> >> >> >> Swami.
> >> >> >> > edit
> >> >> >> > in
> >> >> > the
> >> >> >> > in
> >> >> >> > logic example.
> > like
> >> >> > that
> >> >> >> > of
I
> >> > would
> >> >> > be
> > any
> >> >> >> >> article
editable.
> >> >> >> >> Thanks.
Re: CellEditor tutorial [message #147920 is a reply to message #147896] |
Tue, 17 August 2004 17:17   |
Ok, I stepped into performDirectEdit() and at this point--
EclipseClassLoader(ClassLoader).loadClassInternal(String) line: not
available
--I get this error page:
Class File Editor
Source not found
The jar file rt.jar has no source attachment.
You can attach the source by clicking Attach below
[Attach Source] (button)
abstract public class java.lang.ClassLoader extends java.lang.Object {
news:cft4l7$vrm$1@eclipse.org...
> find
>> performSelection();
>> return true;
>> return false;
> returned
> display)
>> try {
> objects
>> edit
>> part is clicked.
>> > where it stops.
> it
> was
> earlier
>> >> Any suggestions?
>> >> Thanks,
>> >> Swami.
>> > click
>> >> > a
>> >> > "platform"
>> >> > (read
> will
>> >> >> then
> Do
>> >> >> I
>> >> > need
>> >> >> action
>> >> >> newbie
>> >> >> Thanks,
>> >> >> Swami.
> where
>> > you
>> >> >> > could invoke it?
> up:
>> >> >> >> if(manager == null)
>> >> >> >> manager.show();
>> >> >> >> (StickyNoteFigure
>> >> >> >> in
>> >> >> >> my
> the
>> > one
>> >> > on
>> >> >> >> the logic example):
>> >> >> >> gate.add(label);
>> >> >> >> return gate;
>> >> > gate,
>> >> >> >> r);
>> >> >> >> What am I missing?
>> >> >> >> Swami.
>> >> >> >> > edit
>> >> >> >> > in
>> >> >> > the
>> >> >> >> > in
>> >> >> >> > logic example.
>> >> >> >> >> much
>> > like
>> >> >> > that
>> >> >> >> > of
>> >> >> >> >> that
> I
>> >> > would
>> >> >> > be
>> >> >> >> >> was
>> > any
>> >> >> >> >> article
> editable.
>> >> >> >> >> Thanks.
Re: CellEditor tutorial [message #147957 is a reply to message #147920] |
Tue, 17 August 2004 18:21   |
So you need a JDK with src.zip
news:cfteeq$k1p$1@eclipse.org...
> available
> Class File Editor
> Source not found
waits
> > find
> >> performSelection();
> >> return true;
> >> return false;
> > returned
the
> > display)
> >> try {
> > objects
> >> edit
> >> part is clicked.
out
> >> > where it stops.
click
> > it
> > was
> > earlier
> >> >> Any suggestions?
> >> >> Thanks,
> >> >> Swami.
then
> >> > click
> >> >> > a
> >> >> > "platform"
> >> >> > (read
> > will
> >> >> >> then
> > Do
> >> >> >> I
> >> >> > need
the
> >> >> >> action
> >> >> >> newbie
> >> >> >> Thanks,
> >> >> >> Swami.
> > where
> >> > you
> >> >> >> > could invoke it?
> > up:
> >> >> >> >> if(manager == null)
> >> >> >> >> manager.show();
> >> >> >> >> (StickyNoteFigure
> >> >> >> >> in
> >> >> >> >> my
> > the
> >> > one
> >> >> > on
> >> >> >> >> the logic example):
> >> >> >> >> gate.add(label);
> >> >> >> >> return gate;
> >> >> > gate,
> >> >> >> >> r);
> >> >> >> >> What am I missing?
> >> >> >> >> Swami.
the
> >> >> >> >> > edit
> >> >> >> >> > in
> >> >> >> > the
> >> >> >> >> > in
> >> >> >> >> > logic example.
> >> >> >> >> >> much
> >> > like
> >> >> >> > that
> >> >> >> >> > of
> >> >> >> >> >> that
> > I
> >> >> > would
> >> >> >> > be
> >> >> >> >> >> was
> >> > any
> >> >> >> >> >> article
> > editable.
> >> >> >> >> >> Thanks.
Re: CellEditor tutorial [message #147963 is a reply to message #147957] |
Tue, 17 August 2004 19:23  |
Hmm...I changed the JRE that Eclispe uses to one that has src.zip
Now, when I click on the edit part I get the following error:
Unhandled event loop exception
Reason:
But what I'm confused about is that how come the Logic example works with
the other JRE?
Swami.
news:cfti5i$qbm$1@eclipse.org...
>> available
>> Class File Editor
>> Source not found
> waits
>> > find
>> >> performSelection();
>> >> return true;
>> >> return false;
>> > returned
> the
>> > display)
>> >> try {
>> > objects
>> >> edit
>> >> part is clicked.
> out
>> >> > where it stops.
> click
>> > it
>> >> >> I
>> > was
>> > earlier
>> >> >> Any suggestions?
>> >> >> Thanks,
>> >> >> Swami.
> then
>> >> > click
>> >> >> > a
>> >> >> > "platform"
>> >> >> > (read
>> > will
>> >> >> >> then
>> >> >> >> example).
>> > Do
>> >> >> >> I
>> >> >> > need
> the
>> >> >> >> action
>> >> >> >> newbie
>> >> >> >> Thanks,
>> >> >> >> Swami.
>> > where
>> >> > you
>> >> >> >> > could invoke it?
>> >> >> >> >> show
>> > up:
>> >> >> >> >> if(manager == null)
>> >> >> >> >> manager.show();
>> >> >> >> >> (StickyNoteFigure
>> >> >> >> >> in
>> >> >> >> >> my
>> >> >> >> >> as
>> > the
>> >> > one
>> >> >> > on
>> >> >> >> >> the logic example):
>> >> >> >> >> gate.add(label);
>> >> >> >> >> return gate;
>> >> >> > gate,
>> >> >> >> >> r);
>> >> >> >> >> What am I missing?
>> >> >> >> >> Swami.
>> >> >> >> >> > a
> the
>> >> >> >> >> > edit
>> >> >> >> >> > in
>> >> >> >> > the
>> >> >> >> >> > in
>> >> >> >> >> > logic example.
>> >> >> >> >> >> much
>> >> > like
>> >> >> >> > that
>> >> >> >> >> > of
>> >> >> >> >> >> that
>> > I
>> >> >> > would
>> >> >> >> > be
>> >> >> >> >> >> was
>> >> > any
>> >> >> >> >> >> article
>> > editable.
>> >> >> >> >> >> Thanks.
Current Time: Sun Feb 09 03:20:47 GMT 2025
Powered by FUDForum. Page generated in 0.04163 seconds
