Home » Eclipse Projects » Gemini » Gemini Blueprint: NoClassDefFoundError
Gemini Blueprint: NoClassDefFoundError [message #1009803] Fri, 15 February 2013 18:52 Go to next message
eis - is currently offline eis -Friend
I'm getting this
20:30:28,871 ERROR [org.springframework.web.servlet.DispatcherServlet] (ServerSe
rvice Thread Pool -- 852) Context initialization failed: org.springframework.bea
ns.factory.BeanCreationException: Error creating bean with name 'manageclinicres
tcontroller' defined in OSGi resource[classpath:/rest-web-config.xml|bnd.id=52|b
nd.sym=manageclinic-web]: Cannot create inner bean '(inner bean)' of type [org.s
pringframework.beans.factory.config.BeanReferenceFactoryBean] while setting cons
tructor argument; nested exception is org.springframework.beans.factory.BeanCrea
tionException: Error creating bean with name '.org.eclipse.gemini.blueprint.serv
ice.importer.support.OsgiServiceProxyFactoryBean#0': FactoryBean threw exception
on object creation; nested exception is java.lang.NoClassDefFoundError: Could n
ot initialize class $Proxy35
and before that
WARN [org.springframework.beans.factory.support.DefaultListableBeanFactory] (ServerService Thread Pool -- 950) FactoryBean threw exception from getObjectType, despite the contract saying that it should return null if the type of its object cannot be determined yet: java.lang.NoClassDefFoundError: Could not initialize class $Proxy35
with no idea how to debug. Everything should be in order. The bean in question
<bean id="manageclinicrestcontroller"
class="...mypath.ManageClinicRestController">
<argument>
<reference interface="...mypath.ManageClinicService"
availability="mandatory"></reference>
</argument>
</bean>
and with that service bundle, there is
<service ref="manageclinicservice" interface="...mypath.ManageClinicService"
depends-on="manageclinicservicebean">
</service>
any ideas, from where I could start debugging this. Is the problem on which end, on the service or the web layer? Or somewhere else?
Using JBoss AS7 + Gemini BP 1.0.2. Simple, similar other scenarios work with this setup.
[Updated on: Fri, 15 February 2013 19:00]
Report message to a moderator
Re: Gemini Blueprint: NoClassDefFoundError [message #1010873 is a reply to message #1009803] Mon, 18 February 2013 11:33 Go to previous message
Glyn Normington is currently offline Glyn NormingtonFriend
Please note the web support from Spring DM was removed when Spring DM was contributed to become Gemini Blueprint. The recommended replacement is Gemini Web. If you want to use Gemini Web in combination with Spring, I recommend Virgo.
Previous Topic:Best way to use Gemini JPA in Eclipse e4 RCP application
Next Topic:Gemini DBAccess 1.1.0 Release
Current Time: Sun Mar 29 16:50:59 GMT 2020
Powered by FUDForum. Page generated in 0.02596 seconds
