Home » Modeling » Papyrus » [Beginner] Can't find Java types
[Beginner] Can't find Java types [message #1009736] Fri, 15 February 2013 16:02 Go to next message
Arnaud Vandyck is currently offline Arnaud VandyckFriend
Hi all,
I'm testing Papyrus (0.9.1). I'm trying to create a class diagram. I created a class, added a property but I can't assign the java.lang.String type to that property.
Maybe I need to install some additional plugin?
Configure something?
Thanks for your help.
-- Arnaud.
Re: [Beginner] Can't find Java types [message #1009815 is a reply to message #1009736] Fri, 15 February 2013 19:18 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Arnaud,
You need to import a library of types. Select the Model (root package)
in the Model Explorer, right click, and Import -> Registered Package.
The UML Primitive Types library has a String type; maybe the Java
library does, too, (though it's not a Java "primitive").
HTH,
Christian
On 2013-02-15 16:02:29 +0000, avandyck@xxxxxxxx Mising name said:
> Hi all,
> -- Arnaud.
Re: [Beginner] Can't find Java types [message #1015253 is a reply to message #1009815] Wed, 27 February 2013 21:49 Go to previous messageGo to next message
Stefan Begerad is currently offline Stefan BegeradFriend
Hi there,
the library you guys are talking about is called "JavaPrimitiveTypes" and does not contain the "String" type.
Cheers!
Re: [Beginner] Can't find Java types [message #1016144 is a reply to message #1015253] Tue, 05 March 2013 09:12 Go to previous message
Thanks for your answers. Is there a way to import packages from a library? From a jre or any other library?
Previous Topic:Call menu action
Next Topic:Allocation Table: Unresolved reference '/1
Current Time: Sat Jan 23 02:28:55 GMT 2021
Powered by FUDForum. Page generated in 0.01929 seconds
