Home » Archived » BIRT » Evaluate all datasets for nulls
Evaluate all datasets for nulls [message #1009301] Thu, 14 February 2013 16:23 Go to next message
Hi, i am working on a custom report where the customer wants to replace all NULL with 'N/A'. I know how to accomplish this on a per field basis but that can be very tedious and time consuming. I have been looking through the script events when a report is run to determine what is the best place to add code to check for nulls in all datasets and replace them with 'N/A'. Should this be done beforeClose, afterClose, or during the presentation phase?
Any tips on Java code that would perform such action would also be helpful
Mike
Re: Evaluate all datasets for nulls [message #1009454 is a reply to message #1009301] Fri, 15 February 2013 02:06 Go to previous messageGo to next message
Hi Mike,
I have just run a test and it can be done using styles:
In the report create a new style (I named mine null_map)
In the condition use: this.value, equal to, null for the 3 inputs
In your report select the most parental object (i.e. grid) and apply the style
I have only run a simple test, please let me know how you go.
Another way which may work for you if the array assignment is possible:
In the onFetch method of each dataset place the row's fields into separate indexes of an array. Find the length of the array and then loop through its indexes to replace any nulls with N/A, before passing back to the report. It may work and I would be keen to hear if someone has. This method would affect performance, but possibly not very much.
Good luck let me know how you go.
David
Re: Evaluate all datasets for nulls [message #1013045 is a reply to message #1009454] Fri, 22 February 2013 11:58 Go to previous messageGo to next message
David, i tried this method but when i run the report i get an error stating "this.value is invalid"
Re: Evaluate all datasets for nulls [message #1013106 is a reply to message #1009301] Fri, 22 February 2013 14:54 Go to previous messageGo to next message
Correction, i was using uppercase NULL. When i use lowercase null every field is N/A.
Re: Evaluate all datasets for nulls [message #1014830 is a reply to message #1013106] Tue, 26 February 2013 09:53 Go to previous message
Im giving this a bump since someone created a ton of messages with the same topic above.
Anyone have a solution?
Mike
Previous Topic:BIRT ppt report doesn't work with office 2012
Next Topic:Scripted datasource : wrong scope for "this" in Birt 4.2.1
Current Time: Mon Apr 21 05:31:29 EDT 2025
Powered by FUDForum. Page generated in 0.04757 seconds
