Re: Tribix PPT emitter for BIRT WebViewer v4.2.1 [message #1009401 is a reply to message #1009206] |
Fri, 15 February 2013 04:18 |
David Good Messages: 41 Registered: September 2012 |
Member |
Thanks for the quick response Jason, it is appreciated.
I had already followed your post as part of my many attempts to get this working and can now see that my error was how I repackaged the various JAR files. Using jar.exe over-writes the manifest details, causing errors.
I now have the Tribix PPT emitter working successfully, so I have put a step by step process together which closely resembles your xls version. Hopefully anyone else having the same issues may find it useful.
Thanks for the help.
David.
Steps:
1. Extract contents of BIRT runtime JAR in WebViewer\WEB-INF\lib and comment PPT emitter entry in plugin.xml
<!--import from org.eclipse.birt.report.engine.emitter.config.ppt-->
<!-- DG: comment out for Tribix ppt emitter use
<extension name="PPT Emitter Descriptor" point="org.eclipse.birt.report.engine.emitter.config">
<descriptor class="org.eclipse.birt.report.engine.emitter.config.ppt.PPTEmitterDescriptor" id="org.eclipse.birt.report.engine.emitter.ppt"/>
</extension>
2. In the META-INF directory, delete everything except MANIFEST.MF Modify the manifest file as follows:
(** Insert correct version at Bundle-Version)
Manifest-Version: 1.0
Bundle-Vendor: Eclipse.org
Bundle-Name: BIRT Runtime SDK
Bundle-SymbolicName: org.eclipse.birt.runtime
Bundle-Version: 4.2.1.v20120918-1113
3. Create modified JAR named org.eclipse.birt.runtime_4.2.1.v20120918-1113.jar
*** IMPORTANT: on my first attempt I used jar.exe to create the jar but this caused the manifest file to be overwritten with the following.
Created-By: 1.7.0_13 (Oracle Corporation)
Upon startup I got a fatal error: "+ Fatal error occurred when try to startup report engine."
You must ZIP the new contents (i.e. create org.eclipse.birt.runtime_4.2.1.v20120918-1113.jar.zip) then rename the resulting file to .jar, keeping the new manifest in tact.
4. Over-write the existing BIRT runtime JAR in WebViewer\WEB-INF\lib with the new one.
5. Unpack org.uguess.birt.report.engine.emitter.ppt_2.5.2.201107181644.jar
MOVE ppt-emitter.jar to WebViewer\WEB-INF\lib
MOVE lib\poi-3.7-20101029.jar to WebViewer\WEB-INF\lib
MOVE lib\poi-scratchpad-3.7-20101029.jar to WebViewer\WEB-INF\lib
*** Note there were NO commons logging jars in the emitter\lib directory as stated in xls examples:
lib/commons-logging-version.jar
lib/commons-jexl-version.jar
6. Package remaining files into a modified org.uguess.birt.report.engine.emitter.ppt_2.5.2.201107181644.jar
*** IMPORTANT: zip and then rename the contents to keep the manifest in tact. Mine was as follows:
Require-Bundle: org.eclipse.core.runtime,org.uguess.birt.report.engine.common
Bundle-Vendor: Uguess.org
Eclipse-LazyStart: true
Bundle-ClassPath: ppt-emitter.jar,lib/poi-3.7-20101029.jar,lib/poi-scratchpad-3.7-20101029.jar
Bundle-Version: 2.5.2.201107181644
Bundle-Localization: plugin
Bundle-Name: Ppt Emitter Plug-in for BIRT
Bundle-Activator: org.uguess.birt.report.engine.emitter.ppt.Activator
Bundle-ManifestVersion: 2
Bundle-SymbolicName: org.uguess.birt.report.engine.emitter.ppt;singleton:=true
7. Copy MODIFIED org.uguess.birt.report.engine.emitter.ppt_2.5.2.201107181644.jar AND
org.uguess.birt.report.engine.common_2.5.2.201107181644.jar to WebViewer\WEB-INF\lib
8. Modify BirtExportReportDialog.js in WebViewer\webcontent\birt\ajax\ui\dialog adding the if( format=="ppt"){} block:
__exportAction : function( )
else
action = action.replace( reg, "$1=false" );
// use Tribix emitter
if( format=="ppt"){
action = action + "&__emitterid=org.uguess.birt.report.engine.emitter.ppt"
formObj.action = action;
formObj.method = "post";
formObj.submit( );
return true;
9. Move new viewer to Tomcat\webapps directory. Load reports, resources and db drivers where required.
10. Delete temp and work directories from Tomcat home and restart services.
11. Test report successfully exports to PPT 2010.
FUDForum. Page generated in 0.03377 seconds
