Why jubula is giving error that could not couldnot connect to aut? [message #1008912] |
Thu, 14 February 2013 05:39 |
I am developing a test cases using jubula which tests for the multiple instance of single application.But after the 2 test suites executed jubula is throwing an error that it could not able to connect to aut. sometimes this error comes after 5 testsuites executed sometimes it comes after 2.SO i other words i want to say that it is not stable.Can any one tell me what is the problem.
Re: Why jubula is giving error that could not couldnot connect to aut? [message #1012790 is a reply to message #1009438] |
Fri, 22 February 2013 08:32 |
Hi alex
i m running with windows7 64 bit and my processor is pentium 4>again and agian i m runing to the same problem in jubula that it couldnot connect to aut.In windows 7 the problem is coming frequently but in windows xp it is rare but in windows xp after some test it is waiting infinite time to check the text .The same check text is working fine with other test cases.Supoose i have 10 test cases than after 5 to 6 test cases may wait for infinite time to check the text or may not.i have pasted some image of test cases and the pic of the error while it is stopped working with windows7(Couldnot connect to aut)The aut are still there.I have seen in the list.
As per your blog i am using alt+shift+TAB for switching between 2 application .And it is working fine with test cases but in the mid of test suite it is failing like this
[Updated on: Fri, 22 February 2013 09:02] Report message to a moderator
Re: Why jubula is giving error that could not couldnot connect to aut? [message #1015075 is a reply to message #1014998] |
Wed, 27 February 2013 11:21 |
Thanks for the reply alex.
I ensure you that i am trying to connect to connect to the correct aut only.
If i am starting my application test using testexec than could not connect to aut error is not coming.But after running 10 to 12 tstcases the application stops responding and i have to close the application and stop the test.But if i am not using the application with jubula it is working fine. and without testexec also it is working fine but that could connect to aut is error is coming
[Updated on: Thu, 28 February 2013 04:00] Report message to a moderator
FUDForum. Page generated in 0.02251 seconds
