| Reports are failing while closing DataFileReader [message #1008904] |
Thu, 14 February 2013 00:13  |
Reports are failing in our production environment while closing DataFileReader. Below is the stack trace.
SEVERE [org.eclipse.birt.report.engine.api.impl.RunTask.doRun] : An error happened while running the report. Cause:java.lang.NullPointerException
at org.eclipse.birt.data.engine.executor.cache.disk.DataFileReader.close(DataFileReader.java:119)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.closeReader(RowFile.java:284)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.close(RowFile.java:270)
at org.eclipse.birt.data.engine.api.CloseListenerManager.closeAll(CloseListenerManager.java:38)
at org.eclipse.birt.data.engine.impl.DataEngineImpl.shutdown(DataEngineImpl.java:584)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.shutdown(DataRequestSessionImpl.java:509)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.shutdown(AbstractDataEngine.java:348)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.shutdown(DataGenerationEngine.java:151)
at org.eclipse.birt.report.engine.executor.ExecutionContext.closeDataEngine(ExecutionContext.java:900)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:263)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
at com.wellsfargo.reporting.manager.ReportGenerator.sendRequestToEngine(ReportGenerator.java:549)
at com.wellsfargo.reporting.manager.ReportGenerator.runReport(ReportGenerator.java:266)
at com.wellsfargo.reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:45)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:543)
at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:482)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:451)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:323)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:261)
SEVERE [com.wellsfargo.reporting.manager.ReportGenerator.sendRequestToEngine] : Error generating the report :/ccer/design/offline/Decline_Transactions.rptdesign
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
at com.wellsfargo.reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:46)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:544)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:982)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:974)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:876)
at java.lang.Thread.run(Thread.java:637)
We also found another stacktrace from our logs.
error generating report org.eclipse.birt.report.engine.api.EngineException: Exception in reading temporary file for large data set.
Stream closed (Element ID:2634)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCache.next(DiskCache.java:185)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCache.fetch(DiskCache.java:206)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.fetch(SmartCache.java:165)
at org.eclipse.birt.data.engine.executor.transform.group.GroupInformationUtil.doGrouping(GroupInformationUtil.java:466)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:71)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.prepareAggregations(ResultSetProcessUtil.java:154)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.populateResultSet(ResultSetProcessUtil.java:110)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.doPopulate(ResultSetProcessUtil.java:85)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareQueryResultSet(PassManager.java:108)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.pass(PassManager.java:126)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateResultSet(PassManager.java:74)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.populateResultSet
Below is another trace.
ort.engine.api.EngineException: There is an error in saving files of data set cache.
/apps/GTS/tmp/p_wtydm/ccerrep/cache/DataEngine_670338467_23829/DataSetCacheObject_671625063_13907/data.data (Too many open files) (Element ID:2026
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1206)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1185)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:260)
We are using eclipse 3.7 and deploying the reports in BEA WL10.0.2 with JDK 1.5. We are creating only one engine and wrapping it in singleton. We are closing Task and Report documents properly. Reports started working fine after bouncing the server. This has become high priority issue in production. Any help on this is highly appreciated.
Pavan.
FUDForum. Page generated in 0.06049 seconds
