Home » Modeling » OCL » EssentialOCL editing support in papyrus for OrderedSet
EssentialOCL editing support in papyrus for OrderedSet [message #1008707] |
Wed, 13 February 2013 16:28 |
Klaas Gadeyne Messages: 165 Registered: July 2009 |
When creating a reference "myref" in eCore from eClass1 to eClass2 with multiplicity > 1 and setting its properties to { ordered, Unique }, the resulting reference in the context from eClass1, in casu self.myref, is of type OrderedSet, and this syntax is also validated/supported by the OCLinEcore editor.
However, when I create a UML model in Papyrus, that contains 2 classes having the same relation (where the properties of the association end at the Class2 side are set as isOrdered = true, and isUnique = true) and use the embedded essentialOCL editor to create a constraint in the context of Class1, the editor seems to suggest that self.myref is of type Set, and not of type orderedSet as I would expect. Am I missing something here, or is this a bug?
Demo model attached. As you can see, there is an explicit cast "asOrderedSet()" in the contraint expression.
TIA,
Klaas
Edit: Verified using juno SR2-RC2 and Kepler M5 (using the OCL milestone builds for Kepler)
[Updated on: Wed, 13 February 2013 16:31] Report message to a moderator
Re: EssentialOCL editing support in papyrus for OrderedSet [message #1008763 is a reply to message #1008707] |
Wed, 13 February 2013 20:09 |
Ed Willink Messages: 7655 Registered: July 2009 |
I thought for a moment that it might be a combination of unit
multiplicity elements are sets and that one of your properties was
unordered, but after changing them, it still needs asOrderedSet().
Beginning to look very like a bug.
Ed Willink
On 13/02/2013 16:28, Klaas Gadeyne wrote:
> When creating a reference "myref" in eCore from eClass1 to eClass2 with multiplicity> 1 and setting its properties to { ordered, Unique }, the resulting reference in the context from eClass1, in casu self.myref, is of type OrderedSet, and this syntax is also validated/supported by the OCLinEcore editor.
> TIA,
> Klaas
Re: EssentialOCL editing support in papyrus for OrderedSet [message #1008976 is a reply to message #1008763] |
Thu, 14 February 2013 08:31 |
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
<div class="moz-cite-prefix">Hi<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=400744">https://bugs.eclipse.org/bugs/show_bug.cgi?id=400744</a> raised and
fixed. Available tomorrow ion an N-build.<br>
<br>
The pivot-based OCL has some support for bounded nested
collections, so when it's working correctly you see the
multiplicities in the hover text.<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=13414" alt=""><br>
<br>
Regards<br>
<br>
Ed Willink<br>
<br>
<br>
On 13/02/2013 20:09, Ed Willink wrote:<br>
</div>
<blockquote cite="mid:kfgrtr$r28$1@xxxxxxxxe.org" type="cite">Hi
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
<br>
<br>
is this a bug?
<br>
<br>
<br>
<br>
TIA,
<br>
<br>
Klaas
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
Attachment: eijabgdh.png
(Size: 2.27KB, Downloaded 217 times)
Re: EssentialOCL editing support in papyrus for OrderedSet [message #1008978 is a reply to message #1008763] |
<html>
<head>
</head>
<br>
<br>
<br>
<img src="http://www.eclipse.org/forums/index.php?t=getfile&id=13415" alt=""><br>
<br>
Regards<br>
<br>
Ed Willink<br>
<br>
<br>
</div>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ed Willink
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
is this a bug?
<br>
<br>
<br>
<br>
TIA,
<br>
<br>
Klaas
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
(Size: 2.27KB, Downloaded 224 times)
Re: EssentialOCL editing support in papyrus for OrderedSet [message #1009194 is a reply to message #1008978] |
Thu, 14 February 2013 16:29 |
Hi Ed,
Ed Willink wrote on Thu, 14 February 2013 03:31
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400744 raised and fixed. Available tomorrow ion an N-build.
The pivot-based OCL has some support for bounded nested collections, so when it's working correctly you see the multiplicities in the hover text.
I thought for a moment that it might be a combination of unit multiplicity elements are sets and that one of your properties was unordered, but after changing them, it still needs asOrderedSet().
I updated my OCL from the nightly build update site, but that doesn't seem to solve the bug (the syntax is still not valid, nor does the hovering show me the multiplicity). I see two possible reasons:
1/ A problem with the nightly build update site? (The timestamp seems to be from 20130209 instead of 20130214 as I would expect)
OCL End User SDK 4.1.0.v20130209-0216 org.eclipse.ocl.all.sdk.feature.group Eclipse Modeling Project
OCL Examples and Editors 3.3.0.v20130209-0216 org.eclipse.ocl.examples.feature.group Eclipse Modeling Project
2/ The fact that I should adapt something in my UML model, but I fail to see what you mean with your "I thought for a moment" statement above.
And a third option is that I screwed up something else of course
Anyway, thanks a lot for the swift reply/bugfix!
Klaas
Re: EssentialOCL editing support in papyrus for OrderedSet [message #1009260 is a reply to message #1009194] |
Thu, 14 February 2013 19:24 |
For security reasons the build computers cannot push directly to the
downloads area, so builds are pulled by a separate cron job, that for
MDT/OCL runs at about 06:00 GMT, so the N-build won't be accessible
from the downloads page till tomorrow. You can however fetch it direct
from the build at
https://hudson.eclipse.org/hudson/job/buckminster-mdt-ocl-tools-kepler-master/lastSuccessfulBuild/artifact/MDT-OCL.downloads/.
Ed Willink
On 14/02/2013 16:29, Klaas Gadeyne wrote:
> Hi Ed,
>> hover text.
> And a third option is that I screwed up something else of course :)
> Klaas
Current Time: Thu Apr 25 23:34:35 GMT 2024
Powered by FUDForum. Page generated in 0.02989 seconds
