Home » Modeling » Papyrus » Applying mutliple same stereotype
Applying mutliple same stereotype [message #1008665] Wed, 13 February 2013 14:15 Go to next message
E. TOSI is currently offline E. TOSIFriend
I use Stereotype on Properties to generate C# Attributes
When a stereotype is already applied on Property we cannot add the same one multiple times ?
Why this a limitation ?
Thanks in advance,
Papyrus 0.9.0
Re: Applying mutliple same stereotype [message #1008674 is a reply to message #1008665] Wed, 13 February 2013 14:28 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
That is the how the UML Specification defines that stereotypes work:
the upper bound of the ExtensionEnd of a metaclass Extension may not be
more than 1. A stereotype, by definition, can only be applied once.
If your stereotype needs to carry multiple values of its properties,
then its properties need to have multiplicity in themselves.
HTH,
Christian
On 2013-02-13 14:15:18 +0000, E. TOSI said:
> Thanks in advance,
> Papyrus 0.9.0
Re: Applying mutliple same stereotype [message #1008972 is a reply to message #1008674] Thu, 14 February 2013 08:26 Go to previous messageGo to next message
Hi Christian,
Thanks for your response.
I will modify my Stereotypes to accept multiples values and satisfy this UML specification.
Eric
Re: Applying mutliple same stereotype [message #1011338 is a reply to message #1008972] Tue, 19 February 2013 10:52 Go to previous message
A stereotype in UML 2 is not a simple name-value pair as it was in UML 1.x.
Applying a stereotype to a metaclass means changing the metaclass to the
stereptype, i.e., a Class with <<requirement>> is considered to be a
requirement instead of class. So, adding the same stereotype would not make
sense at all.
HTH,
Marc-Florian
"E. TOSI" schrieb im Newsbeitrag news:kfi73a$emd$1@xxxxxxxxe.org...
Hi Christian,
specification.
Eric
Previous Topic:Modeling Papyrus Marte
Next Topic:how to create a popup menu in eclipse using commands and handlers
Current Time: Sun Aug 09 12:27:24 GMT 2020
Powered by FUDForum. Page generated in 0.02131 seconds
