Re: BIRT ppt report with Office 2010 [message #1008516 is a reply to message #1008493] |
Tue, 12 February 2013 19:34 |
Taking a look into it. On the bug, it says a target milestone of 4.2.2, which is set to release this month. But, as you said, it's set to won't fix, so something seems to be conflicting there. I'll let you know what I find out.
Michael
Developer Evangelist, Silanis
Re: BIRT ppt report with Office 2010 [message #1019394 is a reply to message #1018466] |
Fri, 15 March 2013 15:40 |
That page you linked to is for the commercial line of BIRT. The PMC is currently in the process of getting a pptx emitter into the open-source product. Hopefully it'll make it into the next version. The project plan for the next release should come out soon. We should know if it made the cut then.
Michael
Re: BIRT ppt report with Office 2010 [message #1022548 is a reply to message #1022333] |
Fri, 22 March 2013 05:07 |
I'm hoping that the plan is released soon. I don't believe the 4.3 version is slated to come out until June or so, anyways, so there would still be some waiting. The plan should tell us more when it's released.
Michael
Re: BIRT ppt report with Office 2010 [message #1022652 is a reply to message #1022548] |
Fri, 22 March 2013 09:44 |
Mimmo Rossi Messages: 146 Registered: February 2013 |
Michael Williams wrote on Fri, 22 March 2013 01:07I'm hoping that the plan is released soon. I don't believe the 4.3 version is slated to come out until June or so, anyways, so there would still be some waiting. The plan should tell us more when it's released.
Ok i will wait. But I have a doubt, I'll explain: after opening the ppt file exported with version 4.2.2. I noticed that this file is text as you can see from here:
MIME-Version: 1.0
Content-Type: multipart/related; boundary="___Actuate_Content_Boundary___"
--___Actuate_Content_Boundary___
Content-Location: slide-show
Content-Transfer-Encoding: quoted-printable
Content-Type: text/html; charset="utf-8"
<html
xmlns=3D'http://www.w3.org/TR/REC-html40'
xmlns:o=3D'urn:schemas-microsoft-com:office:office'
xmlns:p=3D'urn:schemas-microsoft-com:office:powerpoint'
xmlns:v=3D'urn:schemas-microsoft-com:vml'
<head>
<meta http-equiv=3D'Content-Type' content=3D'text/html; charset=3Dutf-8'>
<meta name=3D'ProgId' content=3D'PowerPoint.Slide'>
<meta name=3D'Generator' content=3D'Actuate View Server'>
<title>null</title>
<xml><o:DocumentProperties>
<o:Author>null</o:Author>
<o:Description>null</o:Description>
<o:Subject>null</o:Subject>
</o:DocumentProperties></xml><link rel=3DFile-List href=3D'file-list'>
<link rel=3DPresentation-XML href=3D'presentation'>
</head></body></html>
Content-Location: s1
<html
<head/><body><p:slide>
If I open it with PowerPoint 2007 and save it, the file becomes binary (and also opens the PowerPoint2010).
My big problem is: as i should concatenate these files together with the POI, and the ppt generated by birt 4.2.2. can not be open with POI becouse has invalid header (becouse isn't a really ppt file), my question is: with the new version of Birt, the file generated is in the same format (so can not be treated by POI) or is in the correct format with correct header of a normal pptx file?
[Updated on: Fri, 22 March 2013 11:06] Report message to a moderator
Re: BIRT ppt report with Office 2010 [message #1061893 is a reply to message #1022652] |
Tue, 04 June 2013 14:44 |
Mimmo Rossi wrote on Fri, 22 March 2013 05:44Michael Williams wrote on Fri, 22 March 2013 01:07I'm hoping that the plan is released soon. I don't believe the 4.3 version is slated to come out until June or so, anyways, so there would still be some waiting. The plan should tell us more when it's released.
MIME-Version: 1.0
<html
<head>
<title>null</title>
<html
Hi Michael,
but with version 4.3 this problem is solved?
thanks in advance
FUDForum. Page generated in 0.05021 seconds
