Home » Modeling » TMF (Xtext) » Xtext templates(Xtext templates)
Xtext templates [message #1008341] Tue, 12 February 2013 04:32 Go to next message
Girish Kumar is currently offline Girish KumarFriend
Member
Hi All,
I wanted to create template for content assist.
The documentation says : you need to create a folder named templates and add templates.xml inside it.
I have created templates.xml by exporting it from the runtime preference page.
The same i added into templates folder of ui plugin.
But it is not working..
Please let me know, i have done anything wrong ??
As a matter of fact, I have also added template folder to exported in build.properties.
Girish
Re: Xtext templates [message #1008354 is a reply to message #1008341] Tue, 12 February 2013 07:12 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
the documentation says a bit more than this!
It is best practice to edit the templates in the preferences page, export them into the templates.xml-file and put this one into the templates folder of your UI-plug-in. However, these templates will not be visible by default. To fix it, you have to manually edit the xml-file and insert an id attribute for each template element. Note that the attribute name is case sensitive. As always in eclipse plug-in development, if the folder templates did not exist before, you have to add it to the bin.includes in your build.properties.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Xtext templates [message #1740360 is a reply to message #1008354] Fri, 12 August 2016 09:25 Go to previous messageGo to next message
Olaf Bigalk is currently offline Olaf BigalkFriend
I did all you mentioned but it does not work either.
Re: Xtext templates [message #1740361 is a reply to message #1740360] Fri, 12 August 2016 09:29 Go to previous messageGo to next message
Stéphane Galland is currently offline Stéphane GallandFriend
In your "lang.ui" project:
* create the folder "templates"
* create the file "templates/templates.xml"
* edit the file with something similar to:
<?xml version="1.0" encoding="UTF-8" ?>
<templates>
	<template
	    name="def"
	    description="public method"
	    id="def"
	    context="io.sarl.lang.SARL.Member"
	    enabled="true"
	    autoinsert="false">def ${name}(${params}) {
		${cursor}
	}</template>
	<template
	    name="protecteddef"
	    description="protected method"
	    id="protected_def"
	    enabled="true"
	    autoinsert="false">protected def ${name}(${params}) {
		${cursor}
	}</template>
</templates>
[Updated on: Fri, 12 August 2016 09:30]
Report message to a moderator
Re: Xtext templates [message #1740363 is a reply to message #1740361] Fri, 12 August 2016 09:34 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
please be aware. the ID is a must must must Wink
Twitter : @chrdietrich
Re: Xtext templates [message #1740365 is a reply to message #1740363] Fri, 12 August 2016 09:53 Go to previous messageGo to next message
I have this templates.xml it resides in the templates folder in the ui project of my plugin and it is enabled in the build section for binary builds.
if I run my plugin in a runtime eclipse the templates are not loaded.
I cannot see my mistake:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<templates>
	<template autoinsert="true"
		context="de.mdsd.xtext.formatter2.model.FormatterModel.FormatterDefinition"
		deleted="false" description="keyword &quot;.&quot; &quot;:&quot;"
		enabled="true" name="keyworddot" id="keyworddot">keyword "." ":" {
			format dot {
			nospace around
	</template>
		deleted="false" description="keyword &quot;,&quot; " enabled="true"
		name="keywordkomma" id="keywordkomma">keyword "," {
			format komma {
			nospace before
			space " " after
	</template>
		deleted="false" description="keyword &quot;;&quot;" enabled="true"
		name="keywordsemicolon" id="keywordsemicolon">keyword ";" {
			format semicolon {
			nospace before
			linewrap(2,0,1) after
	</template>
		deleted="false" description="format linewrapAround(2,1,1)" enabled="true"
		name="linewrapAround" id="linewrapAround">format linewrapAround linewrap (2, 1,1)
		around</template>
		deleted="false" description="pair &quot;(&quot; &quot;)&quot; &quot;[&quot; &quot;]&quot;"
		enabled="true" name="pair()"id="pairparenteses">pair "(" ")" "[" "]" {
			format openParentesis {
			nospace around
			format closingParentesis {
			nospace before
	</template>
		deleted="false" description="pair &quot;{&quot; &quot;}&quot; "
		enabled="true" name="pair{}" id="pairbaces">pair "{" "}" {
			format openBrace {
			space " " before
			linewrap(2, 0, 0) after
			indent after
			format closingBrace {
			linewrap(2, 1, 1) before
			deindent before
	</template>
		context="de.mdsd.xtext.formatter2.model.FormatterModel.FormatDefinition"
		deleted="false" description="use closingBrace" enabled="true"
		name="useclosingBrace" id="useclosingBrace">use closingBrace</template>
		deleted="false" description="use closingParentesis" enabled="true"
		name="useclosingParentesis"id="useclosingParentesis">use closingParentesis</template>
		deleted="false" description="use dot" enabled="true" name="usedot" id="usedot">use dot
	</template>
		deleted="false" description="use komma" enabled="true" name="usekomma"id="usekomma">use komma
	</template>
		deleted="false" description="use semicolon" enabled="true" name="useksemicolon"id="useksemicolon">use
		semicolon</template>
		deleted="false" description="use linewrapAround" enabled="true"
		name="uselinewrapAround"id="uselinewrapAround">use linewrapAround ${Max_Min_Default}</template>
		deleted="false" description="use openBrace" enabled="true" name="useopenBrace"id="useopenBrace">use
		openBrace</template>
		deleted="false" description="use openParentesis" enabled="true"
		name="useopenParentesis"id="useopenParentesis">use openParentesis</template>
</templates>
Re: Xtext templates [message #1740366 is a reply to message #1740365] Fri, 12 August 2016 10:01 Go to previous messageGo to next message
can you try the following
(1) create a bunch of templates with the editor in eclipse
(1b) test them in eclipse
(2) export them
(3) remove those created in eclipse
(4) add the exportted to your template.xml
(5) add the missing ids
(6) start eclipse
[Updated on: Fri, 12 August 2016 10:02]
Re: Xtext templates [message #1760358 is a reply to message #1008341] Wed, 26 April 2017 09:50 Go to previous messageGo to next message
Paul Harrison is currently offline Paul HarrisonFriend
I still have exactly this problem with Xtend 2.11 - can anyone point me to where the templates are loaded so that I can look in the debugger to try to see what might still be wrong.
Re: Xtext templates [message #1760361 is a reply to message #1760358] Wed, 26 April 2017 10:44 Go to previous message
my list missed one point: make sure the templates.xml is mentioned in build.properties
besides this the code for loading it is in org.eclipse.xtext.ui.editor.templates.XtextTemplateStore.loadContributedTemplates()
Previous Topic:ERROR:The method or field .. is undefined for the type ..
Next Topic:scoping.ImportURIScopingFragment in new generator?
Current Time: Sat Sep 23 15:35:40 GMT 2023
Powered by FUDForum. Page generated in 0.02372 seconds
