Home » Modeling » OCL » Property::CompatibleInitialiser' constraint is not satisfied
Property::CompatibleInitialiser' constraint is not satisfied [message #1008140] Sun, 10 February 2013 21:37 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
i am creating Pivot model in a standalone application. I am instantiating model at run time and using Pivot delegates for evaluation. When i try to evaluate then i get following exception
org.eclipse.ocl.common.internal.delegate.OCLDelegateException: 'Property::CompatibleInitialiser' constraint is not satisfied for 'Property test'
at org.eclipse.ocl.examples.pivot.delegate.AbstractDelegatedBehavior.validate(AbstractDelegatedBehavior.java:240)
at org.eclipse.ocl.examples.pivot.delegate.OCLSettingDelegate.get(OCLSettingDelegate.java:66)
at org.eclipse.emf.ecore.util.BasicSettingDelegate$Stateless.dynamicGet(BasicSettingDelegate.java:185)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1027)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
do you have any idea why this is exception is occurring?
thanks!
Re: Property::CompatibleInitialiser' constraint is not satisfied [message #1008266 is a reply to message #1008140] Sun, 10 February 2013 22:11 Go to previous message
As the message says, your OCL is rubbish. In particular your expression
has a "test" Property whose initializer is type-incompatible with the
Property declaration.
Ed Willink
On 10/02/2013 21:37, ModelGeek Mising name wrote:
> 'Property test'
> at
> at
> at
> at
> at
> at
> thanks!
Previous Topic:Getting rid of fully qualified type names in ocl expressions
Next Topic:[OCLinEcore] Import using metamodel URI
Current Time: Fri Sep 20 08:15:39 GMT 2024
Powered by FUDForum. Page generated in 0.04090 seconds
