Home » Eclipse Projects » Eclipse Scout » child page do not decorate untll it's been clicked in an outline based application
child page do not decorate untll it's been clicked in an outline based application [message #1007620] Wed, 06 February 2013 13:24 Go to next message
Let suppose that I have these two classes in an outline based application.
public class MyNodePage extends AbstractPageWithNodes {
private String id;
// @FormData get/setId ...
protected void execDecorateCell(final Cell cell) {
// some decoration code
public class MyTablePage extends AbstractPageWithTable<MyTablePage.Table> {
protected IPage execCreateChildPage(final ITableRow row) throws ProcessingException {
final MyNodePage childPage = new MyNodePage();
childPage.setId((String) row.getCell(this.getTable().getIDColumn()).getValue());
return childPage;
when running my application, everything runs fine and cool, except that I have to click the child node before I get the decoration portion of code being executed, otherwise, the node is labelled as the first column of the TablePage.
what dit I miss, and how ist it possible to get the children nodes automatically decorated once the parent node is expanded?
[System : scout 3.8.1]
thank you!
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007703 is a reply to message #1007620] Thu, 07 February 2013 03:13 Go to previous messageGo to next message
This is a (not so well documented) desired behavior:
When the nodes representing the pages are created in the main windows, a "virtual Page" is created. This virtual page is like a proxy. On click on this virtual page, the corresponding real child page is instantiated (meaning loaded and decorated).
You can influence the virtual page decoration: have a look at execCreateVirtualChildPage(ITableRow) in AbstractPageWithTable.
The virtual page mechanism was added some years ago, because we had performance problem (in case it is expensive to load the child page). I am not sure it is possible to bypass the mechanism.
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007725 is a reply to message #1007703] Thu, 07 February 2013 05:24 Go to previous messageGo to next message
OK, I just changed:
return childPage;
into
protected IPage execCreateVirtualChildPage(final ITableRow row) throws ProcessingException {
return childPage;
and it worked fine!
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007761 is a reply to message #1007725] Thu, 07 February 2013 07:36 Go to previous messageGo to next message
I my opinion this is a misusage of the Virtual pages... I do not know what you do in your "MyNodePage" class and how setting the String Id coming from the IDColumn affects the decoration of the node page.
We have always managed to compute the virtual child page from the Table information (with a hidden summary column and/or with some special logic decorating the virtual page). Just after the user click on the Page, the virtual page is resolved (the real page is instantiated). Because the decoration of the virtual and the real page is the same, the user doesn't see the difference.
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007890 is a reply to message #1007761] Thu, 07 February 2013 19:19 Go to previous messageGo to next message
OK,
I've uploaded an eclipse-ready-to-import sample scout project for you to have a full running code.
I've also uploaded the application's behaviour screenshots for the two cases:
the recommended one; overriding execCreateChildPage witch doesn't match my expected behaviour: I have to click the child node before they decorate.
-- and --
the misusage; overriding execCreateVirtualChildPage witch gives me what I want: nodes are automatically decorated (and displayed as leaves).
I'll be very pleased to have, the suitable solution: correct coding meeting desired bahaviour.
Thank you!
Summary Cell [message #1007940 is a reply to message #1007890] Fri, 08 February 2013 05:54 Go to previous messageGo to next message
Thanks a lot for your example!
I my opinion this is a misusage of the Virtual pages... I do not know what you do in your "MyNodePage" class and how setting the String Id coming from the IDColumn affects the IDColumn.
It will allow me to explain another mechanism:
When the TablePage loads its child pages, it creates a list of virtual pages. The cell used in the node tree to represent the child is derived from the "row summary cell".
A row summary cell is derived from the columns defined as summary. In your example, if I add the summary property to the NameColumn:
		@Order(20.0)
		public class NameColumn extends AbstractStringColumn {
			protected String getConfiguredHeaderText() {
				return TEXTS.get("Name0");
			protected boolean getConfiguredSummary() {
				return true;
I will get:
index.php/fa/13348/0/
(Since I use execCreateChildPage and not execCreateVirtualChildPage, I still have the label change on click)
It is possible to define more than one column as summary column. I can set the summary == true on the IDColumn.
For the summary cell, the labels of the summary columns are collected and (there is a String concatenation with a space between the texts).
I get:
index.php/fa/13349/0/
Something I often do is to add an additional hidden summary column:
With execDecorateCell() in the column, I can control the text.
		@Order(1000.0)
		public class SummaryColumn extends AbstractStringColumn {
			protected boolean getConfiguredDisplayable() {
				return false;
			@ConfigOperation
			@Order(40.0)
			protected void execDecorateCell(Cell cell, ITableRow row) throws ProcessingException {
				final StringBuilder sb = new StringBuilder();
				sb.append('[');
				sb.append(getIDColumn().getValue(row));
				sb.append(']');
				sb.append('[');
				sb.append(getNameColumn().getValue(row));
				sb.append(']');
				sb.append('[');
				sb.append(getNotesColumn().getValue(row));
				sb.append(']');
				cell.setText(sb.toString());
				return true;
I could also set an IconId on the cell.
index.php/fa/13350/0/
Another approach could be to override getSummaryCell(row) in your column, but I am not sure if the Scout API encourage this. (There is no execComputeSummaryCell(row) method).
Side note: If you do it with the summary cells, I think that you can remove "getConfiguredTitle" and "execDecorateCell" from MyNodePage.
I think this post should be merged in the wiki at:
Table > Summary Cell
[Updated on: Fri, 08 February 2013 08:56] by Moderator
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007943 is a reply to message #1007890] Fri, 08 February 2013 06:11 Go to previous messageGo to next message
When I had a look at the example, I figured out it would be good if the Virtual Page already knows it is a leaf:
I imagined something like this:
		 IPage page = super.execCreateVirtualChildPage(row);
		 page.setLeaf(true);
		 return page;
But this is not working because the virtual page doesn't support setLeaf(): the implementation is empty. In my opinion a bug is needed to support the leaf property in VirtualTreeNode.
As workaround extended the VirtualPage like this:
package zzz.zzz.zzz.client.ui.desktop.outlines.pages;
import org.eclipse.scout.rt.client.ui.desktop.outline.pages.VirtualPage;
 * Add the leaf behavior to virtual Pages.
public class VirtualPageEx extends VirtualPage {
	  private boolean m_leaf;
	  public boolean isLeaf() {
	    return m_leaf;
	   * do not use this method directly use ITree.setNodeLeaf(node,b)
	  public void setLeafInternal(boolean b) {
	    m_leaf = b;
	  public void setLeaf(boolean b) {
	    if (getTree() != null) {
	      getTree().setNodeLeaf(this, b);
	    else {
	      setLeafInternal(b);
And I used:
		 page.setLeaf(true);
		 return page;
This provides the expected result (if you use the summary cell).
Re: child page do not decorate untll it's been clicked in an outline based application [message #1007945 is a reply to message #1007943] Fri, 08 February 2013 06:18 Go to previous messageGo to next message
I just reviewed an other part of your code:
Instead of:
	 childPage.setName((String) row.getCell(this.getTable().getNameColumn()).getValue());
	 childPage.setComment((String) row.getCell(this.getTable().getNotesColumn()).getValue());
	 return childPage;
Just write:
	 childPage.setId(getTable().getIDColumn().getValue(row));
	 childPage.setName(getTable().getNameColumn().getValue(row));
	 childPage.setComment(getTable().getNotesColumn().getValue(row));
	 return childPage;
This way you do not have to cast the value (the typed column and the java compiler check this for you).
Re: child page do not decorate untll it's been clicked in an outline based application [message #1008063 is a reply to message #1007945] Fri, 08 February 2013 12:20 Go to previous messageGo to next message
I have tried to merge the content of this post to the wiki:
=> http://wiki.eclipse.org/Scout/Concepts/TablePage (including VirtualPage vs RealPage, and the child-pages in the tree using the summary cell)
=> http://wiki.eclipse.org/Scout/Concepts/Column (summary property is mentioned)
I want to populate the "summary cell" section:
=> http://wiki.eclipse.org/Scout/Concepts/Table#Summary_Cell
Feel free to review / improve it. It is a wiki.
[Updated on: Fri, 08 February 2013 12:23] by Moderator
Re: child page do not decorate untll it's been clicked in an outline based application [message #1008351 is a reply to message #1008063] Tue, 12 February 2013 01:57 Go to previous message
OKKKKKKKKK!
Right
Thank you for all these clarifications, I followed your answer and everything works FINE!
Previous Topic:Export fails on Mac OS X Java 7
Next Topic:Limiting input in FormFields
Current Time: Sun Nov 02 16:28:05 EST 2025
Powered by FUDForum. Page generated in 0.25461 seconds
