Home » Eclipse Projects » BPMN 2.0 Modeler » Remove shelf from pallette
Remove shelf from pallette [message #1007566] Wed, 06 February 2013 14:06 Go to next message
Rui Domingues is currently offline Rui DominguesFriend
Hi. Is that possible to remove an entire shelf from palette via xml?
I'm able to remove objects one by one, but how do I remove a shelf.
Actually I tried to remove the content of DataItems Shelf:
DataStore
DataInput
DataObject
DataOutput,
but DataStore remains there, maybe because it is required by some other object.
Anyway i'd like to remove the shelf itself.
Thanks in advance.
Re: Remove shelf from pallette [message #1007589 is a reply to message #1007566] Wed, 06 February 2013 15:36 Go to previous message
Robert Brodt is currently offline Robert BrodtFriend
Hi Rui,
Currently the only way to remove a palette "drawer" is to disable all of the model elements individually. It sounds like this is the approach you have taken but I'm not sure why DataStore will not go away. You can try disabling the model elements one-by-one from the Project Properties dialog->BPMN2->Tool Enabled and restart the editor until the drawer disappears.
The Tool Enablement project preference looks like this:
http://content.screencast.com/users/rbrodt/folders/Jing/media/564eafc0-b69d-4272-8a07-154db3db1d43/2013-02-06_0833.png
Be sure to enable the "Override" checkbox and click the "Copy" button at the bottom.
The toolpalette configuration still needs work, so feel free to submit an enhancement request!
Bob
Previous Topic:Stacktrace on right click.
Next Topic:extensionElements and CallActivity
Current Time: Mon Jul 06 04:06:12 GMT 2020
Powered by FUDForum. Page generated in 0.04386 seconds
