Error CRRUI2095E [message #1007546] |
Wed, 06 February 2013 06:49  |
Hi all
i saw that the new release of EDT (082) so I tried to install it to see if my OLD problem go away. Once installed the new release I created my test project and when I try to open the HellWorld View.egl I receive this errors message :
Could not render UI
impossible to get the properties's value 'client': void object or not defined
[CRRUI2095E] impossible to find the calls to the function EGL that brings to this error
test1/samples/client/HelloWorldView.html?contextKey=2:22
can some one help me to solve this problem
Re: Error CRRUI2095E [message #1007808 is a reply to message #1007795] |
Thu, 07 February 2013 09:54   |
Richard Moulton wrote on Thu, 07 February 2013 09:08OK, I've learnt something new. I'd never even noticed the example HelloWorld project before when I create projects, but there is some bad news. It works fine for me! CRRUI2095E seems to be a general error, so no help there.
I'm running Windows 7 Enterprise edition (64bit).
What version of Java are you using? Enter 'java -version' at a command prompt.
I get the following ....
java version "1.6.0_33"
Java(TM) SE Runtime Environment (build 1.6.0_33-b03)
Java HotSpot(TM) 64-Bit Server VM (build 20.8-b03, mixed mode)
java version "1.7.0_04"
Java(TM) SE Runtime Environment (build 1.7.0_04-b22)
Java HotSpot(TM) 64-Bit Server VM (build 23.0-b21, mixed mode)
Also, what JRE do you have selected within Eclipse...
Window > Preferences > Java > Installed JREs
See the attached for my settings.
See the attached
What render engine are you using?
Window > Preferences > EGL > Rich UI > Appearance
see the attached
Many thanks for your help
Richard
Attachment: img1.png
(Size: 123.60KB, Downloaded 459 times)
Attachment: img.png
(Size: 52.76KB, Downloaded 481 times)
FUDForum. Page generated in 0.32422 seconds
