Re: Grammar Mixins [message #1007975 is a reply to message #1007459] |
Fri, 08 February 2013 07:17   |
Sebastian Zarnekow Messages: 3117 Registered: July 2009 |
please make sure that the runtime plugin for the definitions language
exports all its packages, esp. the package
org.xtext.example.definitions.services
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.02.13 23:39, schrieb junior developer:
> Hello all ,
> I work grammar inheritance and ı take an error I think this error about
> path (egisterGeneratedEPackage ,registerGenModelFile)but I dont solved
> it :( I try this example from xtext documentation.Add a plug-in
> dependency in the MANIFEST.MF.(add required path in the
> GenerateUsages.MWE2).I generated language artifacts I do not take an
> error when debuging.I take ANTLR error , so that I do not create useges
> extension.Error is in the InternalUsagesParser class(UI package).How
> solve this problem? ,please help me .
> Error:The method getRuleAAccess() from the type UsagesGrammarAccess
> refers to the missing type RuleAElements- The type
> org.xtext.example.definitions.services.DefinitionsGrammarAccess$RuleAElements
> cannot be resolved. It is indirectly referenced from required .class files
> My supergrammar:
> grammar org.xtext.example.definitions.Definitions with
> org.eclipse.xtext.common.Terminals
> generate definitions "http://www.xtext.org/example/definitions/Definitions"
> RuleA : "a" stuff=RuleB;
> RuleB : "{" name=ID "}";
> My subgrammar :
> grammar org.xtext.example.usages.Usages with
> generate usages "http://www.xtext.org/example/usages/Usages"
> import "http://www.eclipse.org/emf/2002/Ecore" as ecore
> Model : (ruleAs+=RuleA)*;
> RuleB : '[' name=ID ']'; //overriding
Re: Grammar Mixins [message #1008129 is a reply to message #1007975] |
Sun, 10 February 2013 12:28   |
junior developer Messages: 354 Registered: January 2013 |
Hi Sebastian,
When I generate the language code, I receive previously mentioned error for InternalUsagesParser class in org.xtext.example.usages.ui.contentassist.antlr.internal package. The error occures in the grammarAccess.getRuleAAccess() function call of the automatically generated ruleRuleA() function. Interestingly the project works without any problem. I write programs in the editor and I don't take any error, e.g. I can use overriding rule.
Could you possibly introduce me a solution to resolve this error?
Best regards
[Updated on: Sun, 10 February 2013 12:31] Report message to a moderator
Re: Grammar Mixins [message #1008672 is a reply to message #1008658] |
Wed, 13 February 2013 14:24   |
i dont get your point. the package doesnt matter, the binding counts
public Class<? extends org.eclipse.xtext.parser.antlr.ISyntaxErrorMessageProvider> bindISyntaxErrorMessageProvider() {
return MySyntaxErrorMessageProvider.class;
you may bind it in the runtimemodule or in the ui module only depending on your needs
Twitter : @chrdietrich
Re: Grammar Mixins [message #1009609 is a reply to message #1009555] |
Fri, 15 February 2013 11:32   |
HI,
sorry i do not get it? i cannot teach you how to write java
import org.eclipse.xtext.GrammarUtil;
import org.eclipse.xtext.IGrammarAccess;
import org.eclipse.xtext.nodemodel.SyntaxErrorMessage;
import org.eclipse.xtext.parser.antlr.SyntaxErrorMessageProvider;
import com.google.inject.Inject;
public class MyDslSyntaxErrorMessageProvider extends SyntaxErrorMessageProvider {
public static final String USED_RESERVED_KEYWORD = "USED_RESERVED_KEYWORD";
@Inject
IGrammarAccess grammarAccess;
public SyntaxErrorMessage getSyntaxErrorMessage(IParserErrorContext context) {
if (context.getRecognitionException() != null
&& context.getRecognitionException().token != null) {
String unexpectedText = context.getRecognitionException().token
.getText();
if (GrammarUtil.getAllKeywords(grammarAccess.getGrammar())
.contains(unexpectedText)) {
return new SyntaxErrorMessage(
unexpectedText
+ " is a reserved keyword which is not allowed as Identifier",
USED_RESERVED_KEYWORD);
return super.getSyntaxErrorMessage(context);
Re: Grammar Mixins [message #1010716 is a reply to message #1010074] |
Mon, 18 February 2013 05:01   |
Hi Christian,
My problem is to change default automatic validation error and warning messages and looking for a general solution how to do that.
I've got an example written in xtend-class (see below). I want to extend this code. For different or existing automatic validation error and warning messages I want to add custom messages. For example, I get for Cross-reference an error message ** Couldn't resolve reference to Name 'something' ** which is an automatic validation error, so I want to add or overide with my own code to get my error message something like that ** You cannot call 'something' **. Which functions do I need to realize that and where should I add this to existing keywords. I didn't have found enough sources to get this run, can you give me a hint how to realise it?
package org.xtext.example.mydsl1.ui;
public class MyDsl1SyntaxErrorMessageProvider extends SyntaxErrorMessageProvider {
@Inject
/* I want to change Cross Reference Default Error Message:Couldn't resolve reference to Name 'something'... in my own custom message */
if (context.getRecognitionException() != null && context.getRecognitionException().token != null) {
String unexpectedText = context.getRecognitionException().token.getText();
if(GrammarUtil.getAllKeywords(grammarAccess.getGrammar()).contains(unexpectedText)) {
return new SyntaxErrorMessage( "is a reserved keyword which is not allowed as Identifier",USED_RESERVED_KEYWORD);//changed Automatic validation (mismatched input //'Hello' expecting RULE_ID)
[Updated on: Mon, 18 February 2013 07:41] Report message to a moderator
Re: Grammar Mixins [message #1744557 is a reply to message #1008211] |
Wed, 28 September 2016 09:11  |
Martin Westerkamp Messages: 9 Registered: September 2016 |
junior developer wrote on Mon, 11 February 2013 13:41My problem is solved.
Could you please let us know how you solved the problem? I'm struggling with the same issue right now.
EDIT: I just figured out the solution. The plug-in of the super language needs to be added to the manifest.mf file of the .ide project of the sub language.
[Updated on: Wed, 28 September 2016 09:30] Report message to a moderator
FUDForum. Page generated in 0.03180 seconds
