Home » Modeling » UML2 » Any way to set the default value for a LiteralInteger explicitly?
Any way to set the default value for a LiteralInteger explicitly? [message #1007386] Tue, 05 February 2013 17:13 Go to next message
Ellen Badgley is currently offline Ellen BadgleyFriend
Member
I'm running into a situation where I'm generating a UML2 model programmatically, then importing it into Enterprise Architect. I'm having the issue that when I have a LiteralInteger specification where the value is the same as the default (0), the lack of explicit serialization of that value results in it not being recognized by EA.
For example, in the following series of enumeration literals:
<ownedLiteral xmi:id="1" name="noInformation">
<specification xmi:type="uml:LiteralInteger" xmi:id="1_1" value="-999999"/>
</ownedLiteral>
<ownedLiteral xmi:id="2" name="unknown">
<specification xmi:type="uml:LiteralInteger" xmi:id="2_1"/>
</ownedLiteral>
the "value" for the second literal is supposed to be 0, but EMF/UML2 does not store the value since it is the same as the default.
I have a support request in to Sparx Systems about this issue, but I am wondering, in the meantime, if there is any way to "force" the UML2 API to create the "value" attribute even though it matches the default. Is this possible?
Re: Any way to set the default value for a LiteralInteger explicitly? [message #1007391 is a reply to message #1007386] Tue, 05 February 2013 17:21 Go to previous messageGo to next message
You just need to set XMLResource.OPTION_KEEP_DEFAULT_CONTENT in your
Resource save options.
Ed Willink
> value="-999999"/>
> </ownedLiteral>
> </ownedLiteral>
Re: Any way to set the default value for a LiteralInteger explicitly? [message #1007426 is a reply to message #1007391] Tue, 05 February 2013 19:48 Go to previous messageGo to next message
Member
Ed,
Thanks! That would do the trick.
Looking in the archives I see this subject has been discussed multiple times, but I beg your indulgence: I'm not entirely sure how OPTION_KEEP_DEFAULT_CONTENT would be set in my case, as I'm using the default resource factory for UML2 files.
(I'm also still on Indigo; haven't made the jump to Juno yet for varying reasons, but if it's unavoidable I'll do so.)
Re: Any way to set the default value for a LiteralInteger explicitly? [message #1007432 is a reply to message #1007426] Tue, 05 February 2013 20:17 Go to previous messageGo to next message
You just the extra options argument to Resource.save(Map).
This hasn't changed for years and years.
Ed Willink
On 05/02/2013 19:48, Ellen Badgley wrote:
> Ed,
Re: Any way to set the default value for a LiteralInteger explicitly? [message #1007433 is a reply to message #1007432] Tue, 05 February 2013 20:23 Go to previous messageGo to next message
Member
Thanks. There's a lot I still don't know, as you can tell!
Re: Any way to set the default value for a LiteralInteger explicitly? [message #1007604 is a reply to message #1007433] Wed, 06 February 2013 17:20 Go to previous message
Member
I'm unfortunately still not getting the defaults. The code I'm using to save the resource is below:
Map<String,Boolean> options = new HashMap<String, Boolean>();
options.put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, Boolean.TRUE);
resource.save(options);
The "offending" elements are literal integers created as value specifications, for an enumeration literal or otherwise, via the following
EnumerationLiteral literal = enumeration.createOwnedLiteral(name);
LiteralInteger litint = org.eclipse.uml2.uml.UMLFactory.eINSTANCE
					.createLiteralInteger();
litint.setValue(Integer.parseInt(this.secondaryCode)); //the value will occasionally be 0
literal.setSpecification(litint);
Previous Topic:Building an GMF-based editor for an definde UML-profile
Next Topic:Get All Stereotype of Element ( getAppliedStereotypes )
Current Time: Sat Jul 11 15:27:34 GMT 2020
Powered by FUDForum. Page generated in 0.02390 seconds
