Home » Archived » BIRT » Hide rows description in crosstab(Minimize gap between two aligned crosstabs)
Hide rows description in crosstab [message #1007291] Tue, 05 February 2013 11:52 Go to next message
Tomas Greif is currently offline Tomas GreifFriend
Member
I do have to display two crosstabs side-by-side. I can do this by tweaking some formatting, however I'm not able to decrease gap between crosstabs. I've set padding/borders everywhere to 0, set font size to 1 pixel, but still the gap is too big. I'm attaching picture of what I have so far.
Is there any way how I can further decrease the gap?
Re: Hide rows description in crosstab [message #1007332 is a reply to message #1007291] Tue, 05 February 2013 14:49 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
You could try figuring out what the row header and row dimension cell Id's are, and putting this script into your crosstab's onRender script:
function onRenderCell( cellInst, reportContext )
if(cellInst.getCellID() == 38 || cellInst.getCellID() == 42){ //replace these two Id's with your values
cellInst.getStyle().setDisplay("none");
This got them close for me. I then went to the right crosstab and set its left margin to -4. That seemed to do it.
Hope this helps.
Michael
Developer Evangelist, Silanis
Re: Hide rows description in crosstab [message #1007338 is a reply to message #1007332] Tue, 05 February 2013 15:09 Go to previous messageGo to next message
Member
Michael, thank you for your response. By Cell ID you mean "Element ID" or something else?
Tomas
[Updated on: Tue, 05 February 2013 15:09]
Report message to a moderator
Re: Hide rows description in crosstab [message #1007365 is a reply to message #1007338] Tue, 05 February 2013 16:05 Go to previous messageGo to next message
Yeah. That'll be the same thing as cellID. Sorry. Let me know.
Michael
Re: Hide rows description in crosstab [message #1007525 is a reply to message #1007365] Wed, 06 February 2013 10:28 Go to previous messageGo to next message
Member
OK, I've found I can set "No Display" directly in BIRT Report Designer. Using this and negative margin I've managed to do what I want.
Thank you for your help.
Tomas
Re: Hide rows description in crosstab [message #1007622 is a reply to message #1007525] Wed, 06 February 2013 18:53 Go to previous message
No problem.
Michael
Previous Topic:Disable fully Birt logging
Next Topic:BIRT Bubble Chart not exporting to pdf
Current Time: Sat Apr 01 09:12:33 GMT 2023
Powered by FUDForum. Page generated in 0.02147 seconds
