Home » Modeling » GMF (Graphical Modeling Framework) » Wizard for creating a model file
Wizard for creating a model file [message #1007278] Tue, 05 February 2013 05:49 Go to next message
I wonder if it's possible to have a wizard which simplifier the creation of new model files.
By now, I've to create an new Project and then adding a file with a specific file extension. Is it possible to have maybe a wizard, called "Create MyDSL Project", where you give a name and the rest is done automatically?
Re: Wizard for creating a model file [message #1007539 is a reply to message #1007278] Wed, 06 February 2013 06:08 Go to previous message
got to the plugin.xml of you generated plugin. Select the Extensions tab. There you will find org.eclipse.ui.newWizards. This should be a good starting point for you.
Ralph
Previous Topic:Model to Code
Next Topic:Split connection between two nodes when placing a new node on the connection
Current Time: Thu Nov 13 12:47:33 EST 2025
Powered by FUDForum. Page generated in 0.04753 seconds
