Hudson 3.0 and Copy artifacts plugin issue [message #1007266] |
Tue, 05 February 2013 10:06 |
it seems that "Copy artifacts plugin" does not behave correctly after migration to Hudson 3.0.0 from 2.2.0, it copies almost everything (but I don't notice what exactly) and not only artifacts that are archived.
The plugin version that I'm using is 1.23-h-1 and it seems to be the latest version.
Hudson proposes to downgrade to 1.12, can it be the right thing to do?
I'm not sure where to report this issue. Is it a plugin hosted at Eclipse?
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007336 is a reply to message #1007331] |
Tue, 05 February 2013 15:04 |
effectively, it is the same issue.
For my configuration:
I specified a project name
Which build --> Latest successful build
I can specify target directory or not, same behavior
I can enable Flatten directories or not, same behavior
Hudson is running on Java 1.6:
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.5) (6b24-1.11.5-0ubuntu1~10.04.2)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
Re: Hudson 3.0 and Copy artifacts plugin issue [message #1007346 is a reply to message #1007336] |
Tue, 05 February 2013 15:30 |
sorry for double-posting but:
I downgraded the plugin to 1.12 version and it is working.
But in log I have the following error several times when loading the plugin at startup:
Feb 5, 2013 12:15:53 PM hudson.util.RobustCollectionConverter populateCollection
WARNING: Failed to resolve class hudson.plugins.copyartifact.CopyArtifact$EnvAction
It seems that there is no bad effect on my jobs even with these stacks.
FUDForum. Page generated in 0.03467 seconds
