RAP browser scrolling [message #1007250] |
Tue, 05 February 2013 09:22 |
What is the suggested method to enable scrolling within the browser for a RAP application? This would be for shells run in fullscreen mode:
newShell.setFullScreen(true)
...and also displays containing a number of shells of different sizes NOT in fullscreen mode too.
Where the overall design and position/size of the shells is larger than the browser can fit in, how do you enable browser scrolling to be able to get to them?
Currently you just get placed at some position and cannot scroll around to get to the rest of the widgets on the shells, or indeed other shells that happen to be off the browser's current view.
I don't really want to use scrolled composites, as I need to have the flexibility of multiple shells too.
Surely I have missed some obvious property that switches scrolling on/off for the browser?
Presumably there is also something that enables resize in the browser too? I've tested my RAP application on a number of devices in their browser, and the usual pinch to resize has no effect, so it appears that it is deliberately switched off for the RAP application...?
Thanks, John
Just because you can doesn't mean you should
Re: RAP browser scrolling [message #1007536 is a reply to message #1007250] |
Wed, 06 February 2013 10:55 |
Tim Buschtoens Messages: 396 Registered: July 2009 |
Hi.
No.
Though we considered it, we did not (yet) enable page scrolling in RAP,
mostly for potential cross-browser and mouse coordinate issues. It's not
at all out of the question as a feature, we just don't know yet what
exactly the consequences might be. It's also a bit more work than just
change one or two css properties, since some javascript code might rely
on the page not to be scrolled.
There is a bug for this, though the hack mentioned won't work anymore:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=355852
Yes, we did this on purpose too, but you should be able re-activate it.
In the RAP html page that contains the application, there is a tag in
the head:
"<meta name="viewport" content="initial-scale=1.0, minimum-scale=1.0,
maximum-scale=1.0" >"
Using ApplicationConfiguration or Branding you can add meta tags/html to
the sites head, which should allow you to overwrite this with another
meta tag of the same type and other values. Should that not work, then
you'd have to change the rwt-index.html file directly in the rwt bundle.
However, all this is not officially supported, so any issues that result
from that change are currently not considered bugs.
I how that helps. If you need that scrolling feature you should vote on
the bug. More votes make it more likely to be implemented.
Greetings,
Tim
> Thanks, John
Tim Buschtöns
Twitter: @EclipseRAP
Re: RAP browser scrolling [message #1011447 is a reply to message #1007536] |
Tue, 19 February 2013 15:11 |
Thanks Tim.
I have voted for the bug, to have scrolling supported by default in RAP.
I couldn't get the resize working though... the meta tags via Branding didn't appear to have any effect and I'm not using ApplicationConfiguration. Interestingly, IE and Chrome (probably other PC-based browsers) give you zoom feature anyway, but the pinch-style resize didn't work on Chrome on my Android device.
Not a big deal I guess, but it would be good to get support for pinch-style resize on device browsers working some time in the not-to-distant future.
Thanks, John
FUDForum. Page generated in 0.03191 seconds
